Re: No Robot Code on Driver Station
Try running a kernel task instead of deploying it and seeing if you get any errors such as an Unresolved Symbol. Are you using the new Command based methodology?
Get a target console up, and you should see some errors.
An easy one this year is if your modules are in the wrong slots. Whereas the digital sidecar was cRio slot 4 last year, it is now slot 2. Slot 1: Analog Slot 2: Digital Slot 3: Solenoid |
Go to window then Preferences and under First Downloader, make sure your team number is there and the path to your executable.
