Go to Post There is nothing that says 'gracious professionalism' like making brunch for your opponents. - Monochron [more]
Unread 01-18-2012, 06:34 PM
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
2012 crio II encoder java constructor
We purchased a new 4 slot crio to test for this year. During our testing we installed a digital sidecar in slot number 2. Then we plugged an encoder into dio ports 1 and 2. We tried to read from the encoder by constructing it the following way:
shooterSpeed = new Encoder( 2, 1, 2, 2, true, Encoder.EncodingType.k4X)
This constructor takes slot, port, slot, port, ... So we specified slot 2 port 1 slot 2 port 2. This didn't seem to work. All readings were 0.
During our debug we decided to try specifying slot 1 instead of slot 2. Suddenly the encoder began to function.
shooterSpeed = new Encoder( 1, 1, 1, 2, true, Encoder.EncodingType.k4X);
Has anyone else experienced something like this? This is pretty strange because slot 1 has the analog breakout plugged in to it.
Unread 01-18-2012, 09:50 PM
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: 2012 crio II encoder java constructor
I think there was a bug last year, can't exactly remember, but you may have to use Encoder.EncodingType.k2X or write your own Encoder.EncodingType.k4X
Unread 01-18-2012, 09:56 PM
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Check the wiring. We were trying to debug the encoders for like 2 weeks because of faulty wiring.
Unread 01-18-2012, 10:10 PM
This is how it is supposed to work from now on. It no longer references slot number, but references which module. The first digital module (in slot 2 of both cRIOs) is 1. The second digital module (in slot 4 of the new cRIO or slot 6 of the old cRIO) is 2. This is so you don't have to change your code to switch between cRIOs.
The bug you are probably thinking of had to do with the rate output, and would be unrelated to this problem. It was also fixed this year.
