Go to Post Engineering is a career of continuous learning, acquiring new skills, and growth. - KenWittlief [more]
Unread 13-01-2012, 20:59
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
camera returning error when getting instance
I am using
AxisCamera.get instance("10.2.28.11")
And I'm getting a long error containing error connecting to camera
Unread 13-01-2012, 22:46
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: camera returning error when getting instance
Is that the exact line that you're using? If so, getInstance should be a camelcase single word, and there should be something at the end - further instructions or a semicolon.
Have you run the Axis Camera setup utility? If the camera has been connected to the cRIO, you must use the utility before connecting it to the bridge. Also, it may be a problem if the camera is connected to the bridge via a crossover cable, though I am not sure. I definitely know that a cat5 (Ethernet) cable works.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 13-01-2012, 23:02
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
I've been using a crossover successfuly. If that is the actual code, I am sure the code is erroring, not the camera, since the code won't be loaded. Could you copy and paste the exact error here?
Unread 14-01-2012, 22:43
FRC #0228 (Gus)
Sorry i had to type on a tablet the code i used was
AxisCamera.getInstance();
And i did not set it up with the utility i just set its ip address to 10.xx.xx.11
Does the utility give it a special username and password for the cRIO to connect to? if so ill have to try using it its kinda weird and hasent worked for me yet.
EDIT:
Ah, i looked in the documentation and i was right.. it does set up a user and pass for the Crio... ok Thanks anyway
Unread 14-01-2012, 22:48
add the Username and Password combo FRC/FRC
set it up manually, many have reported issues with the tool that were confirmed by Greg McKaskle from NI.
Unread 14-01-2012, 23:16
FRC #0228 (Gus)
Alright thanks,
Unread 18-01-2012, 18:54
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
I'm a java programmer trying to get the camera we got last year working, and I am not getting a image. I am using getInstance(XXX);, but I don't have any idea where I put the username/password combo? Is it in the code, and what do I write? Thanks
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 18-01-2012, 22:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
FRC/FRC should be used by default.
