Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 18-01-2012, 18:55
pentrium pentrium is offline
FRC #1075
pentrium is an unknown quantity at this point
No Robot Code
After deploying our robot code from windriver, the driver station says that there is no robot code. Does anyone have any suggestions as to how to solve this problem?
Unread 19-01-2012, 20:24
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Re: No Robot Code
Go to window then Preferences and under First Downloader, make sure your team number is there and the path to your executable.
Unread 19-01-2012, 22:49
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
Re: No Robot Code
The exact file path should be:
C:\Windriver\workspace\[project name]\PPC603gnu\SimpleTemplate\Debug\SimpleTemplate.Out
correct?
Unread 19-01-2012, 23:24
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: No Robot Code
Try restarting the robot. We were having similar troubles and we ended up just needing a good ol' reboot.
Unread 20-01-2012, 00:20
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Re: No Robot Code
Make sure your code is ACTUALLY uploading to the robot. It may be moving on the status bar, but it may not have a good connection. Check your IP. If you are using a computer that is NOT the classmate, your IP should be "10.xx.xx.6".
My team # is 1138, so mine would be 10.11.38.6
If you are on your classmate, your IP should be 10.xx.xx.5
Make sure your subnet is 255.255.255.0
Just make sure you are connecting properly, you have your team # in the text box under Options->Preferences->First Downloader Preferences (or something like that). Also, make sure your output path is correct.
Any questions, just ask me.
-Eagle Engineering 1138
