Go to Post Stop making me think so hard! :D - Chris is me [more]
Unread 18-01-2012, 18:58
Data Nerd
FRC #0079
Re: pic: CD 7 ball harvester
You weren't I just didn't need to look at it since I had it handy in my head the day of kickoff
Originally Posted by BrendanB View Post
Team RUSH27 had something very similar in 2006.
And 08 if you look close. (I cheated, my brother helped build their 08 bot)
Originally Posted by Alex.q View Post
I like it, but it looks heavy and how much time would something like this really save you in collecting the balls? Is it really necessary?
It can be done lightly.
Unread 18-01-2012, 19:01
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
How well would you say it worked out for you in 2006/how much did you use it?
I know you used it in 2008 but the application was a little different then a drop down harvester for smaller objects!
1058 PVC Pirates 2016 - xxxx
Unread 18-01-2012, 19:04
Data Nerd
FRC #0079
I was a pretty big fan in 06. It basically said that when we touched the ball it was ours. Similar in 08. It also helped with getting balls out of corners.
Unread 18-01-2012, 20:01
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Which is itself great, but it also appears to solve the many into one problem, no?
is there much of a problem if you are trying to move the robot while picking up?
Unread 18-01-2012, 20:06
Data Nerd
FRC #0079
I don't recall there being a huge one but that will also be a function of the rate you are moving compared to the rate the belts are running.
Unread 12-05-2012, 22:16
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
ANy inventor CAd file for other if so add it on FRC design help out the cad community
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Chief 47 ball harvester 2002 pics ajlapp Robot Showcase 6 11-01-2006 15:34
pic: Center Player Station and Ball Drop Wetzel Extra Discussion 2 08-01-2006 17:40
pic: Team 980 grabs 2X ball 3 seconds into Galileo QF3.1 CD47-Bot Extra Discussion 9 06-05-2004 02:31
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
