Go to Post Does that mean that the Ultimate Question of Life, the Universe, and Everything is, "How many total tubes will be available to score for the FRC 2011 game, LogoMotion? - EricH [more]
Unread 18-01-2012, 20:00
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Weird PWM behaviour?
We've just assembled our electrical board and we're having some really really strange issues with the Jaguar.
The Jaguar (currently we only have 1 attached) is connected to the digital sidecar on PWM1. By initializing a new Jaguar via Jaguar j = new Jaguar(1); I can't control the Jaguar and it blinks yellow after enabling the robot.
However, if I initialized the Jaguar using new Jaguar(4). It works flawlessly (except for the whole wrong channel number thing)...
Any idea why this is?
Unread 18-01-2012, 20:57
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Which language is this and us the pwm plugged in in the right orientation
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 18-01-2012, 21:06
Re: Weird PWM behaviour?
Java, and Yes.
Unread 18-01-2012, 21:29
There was another thread that discussed this same problem. I would search for that as I remember it was answered.
Unread 18-01-2012, 22:00
TofuRama TofuRama is offline
01000110 01010010 01000011
AKA: Matt
FRC #2484 (Team Implosion)
TofuRama is an unknown quantity at this point
FIRST released an update a while ago that addressed the issue. Apparently, most of the KOP cables that connect the cRIO to the digital sidecar this year aren't properly wired. Here's a link to the update and to the fix:
http://frc-manual.usfirst.org/TeamUpdates/0#term%2074
Good luck and I hope this helps!
Unread 19-01-2012, 11:29
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
We have been having the same issue the last few days. Using a multimeter, we did not see voltage on the PWM pins.
I did some additional research last night and found that the slot arrangements on the CRIO have changed, and may have to be accounted for when constructing the jaguar.
If I remember correctly, the digital sidecar needs to go in either slots 2 or 6 this year, if it is in slot 2 your code is fine, but if it's in slot 6 you must modify to:
Jaguar j = new Jaguar(2,1); //the channel must be 2 for a digital car in slot 6.
(note: I'm programming in C++ and this is valid, but you may want to make sure the channel is the first param for Java)
I haven't had a chance to test if this resolves our issue, but I've got a good feeling hope this can help.
Last edited by DjScribbles : 19-01-2012 at 11:30. Reason: added disclaimer for java constructor
