Go to Post You can't please all the people all the time. The rationale of "lots of people don't like it" is not a reason to stop doing it. - Karthik [more]
Unread 17-01-2012, 13:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Window Motors and Rotation
To make the motor turn in precise increments, requires feedback and motor control. Use an encoder (a potentiometer will probably work and only costs $3 at Radio Shack) and a Victor or Jaguar instead of a Spike to drive it. Then you'll get to discover the joys of a PID loop, and getting the constants right.
The potentiometer is mounted so it moves as the motor moves, and connected to an analog input.
Unread 17-01-2012, 14:43
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by Roboticsismylif View Post
You should have gotten 4 window motors, two right and two left. They have moderate speed and lots of torque. As for coding they use a "spike" relay. The coding should be the same for them as any other spike. With the spike you can reverse the flow of energy making the window motor turn the opposite dirrection.
There were only 2 window motors, weren't there?
Unread 18-01-2012, 21:22
Two motors in the KOP, up to two additional available through the ARA program.
