Go to Post .......I would still heed Al's suggestions above. He has many a grey hair and he earned them all the old-fashioned way. :) - Richard Wallace [more]
Unread 18-01-2012, 22:10
Re: 2012 crio II encoder java constructor
Originally Posted by Secretspy97 View Post
Has anyone else experienced something like this? This is pretty strange because slot 1 has the analog breakout plugged in to it.
This is how it is supposed to work from now on. It no longer references slot number, but references which module. The first digital module (in slot 2 of both cRIOs) is 1. The second digital module (in slot 4 of the new cRIO or slot 6 of the old cRIO) is 2. This is so you don't have to change your code to switch between cRIOs.
Originally Posted by kinganu123 View Post
I think there was a bug last year, can't exactly remember, but you may have to use Encoder.EncodingType.k2X or write your own Encoder.EncodingType.k4X
The bug you are probably thinking of had to do with the rate output, and would be unrelated to this problem. It was also fixed this year.
