Go to Post If you want something done about it, than do something about it. - Tetraman [more]
Unread 18-01-2012, 19:12
RcDawson RcDawson is offline
FRC #2972
RcDawson has a spectacular aura aboutRcDawson has a spectacular aura about
Cannot deploy Java code through netbeans
Our team is not having any luck deploying code to the cRIO. We are getting the following error
Connecting FTP @10.29.72.2
C:\Users\Developer\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\Users\Developer\sunspotfrcsdk\ant\upgrade.xml:39:
java.net.SocketException: Software caused connection abort: socket write error
        at java.net.SocketOutputStream.socketWrite0(Native Method)
        at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:109)
        at java.net.SocketOutputStream.write(SocketOutputStream.java:153)
        at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)
        at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)
        at org.apache.commons.net.telnet.TelnetClient._flushOutputStream(TelnetClient.java:77)
        at org.apache.commons.net.telnet.TelnetOutputStream.flush(TelnetOutputStream.java:137)
        at java.io.FilterOutputStream.flush(FilterOutputStream.java:140)
        at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:297)
        at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
        at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
        at java.io.BufferedWriter.flush(BufferedWriter.java:254)
        at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:442)
        at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:520)
        at org.apache.commons.net.ftp.FTP.port(FTP.java:849)
        at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:477)
        at org.apache.commons.net.ftp.FTPClient.retrieveFile(FTPClient.java:1285)
        at com.sun.spot.sdk.tool.ftp.UpgradeTask.checkVersion(UpgradeTask.java:34)
        at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(UpgradeTask.java:215)
        at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
        at sun.reflect.GeneratedMethodAccessor112.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
        at org.apache.tools.ant.Task.perform(Task.java:348)
        at org.apache.tools.ant.Target.execute(Target.java:390)
        at org.apache.tools.ant.Target.performTasks(Target.java:411)
        at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1397)
        at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
        at org.apache.tools.ant.Project.executeTargets(Project.java:1249)
        at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442)
        at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
        at org.apache.tools.ant.Project.executeTarget(Project.java:1366)
        at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
        at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:281)
        at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:539)
        at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:154)
BUILD FAILED (total time: 20 seconds)
We can ping the cRIO and connect with FTP manually. We have also tried Netbeans version 6.9.1 and 7.1. Any ideas?
Unread 18-01-2012, 22:15
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Re: Cannot deploy Java code through netbeans
Is there anything printed before this stack trace?
Unread 19-01-2012, 03:00
AKA: Brad
#0190 ( Gompei and the Herd)
Can you try disabling the firewall temporarily to see if that helps? It seems like FTP isn't getting to your cRIO (that's what deploys the code). Also, you might verify that you can ping the robot from the same computer to make sure that the network is set up properly.
Brad
Brad Miller
Robotics Resource Center
Unread 19-01-2012, 05:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I am currently having this issue on two of our laptops.
A Sony Vaio netbook running 32-bit Windows 7
and
A MacBook Air running BootCamp + 64-bit Windows 7
Both computers can ping the cRIO at 10.xx.yy.2 just fine.
We've disabled the firewall on both, as well as made explicit exceptions for NetBeans. The problem still exists.
We've resorted to using different laptops for sending code.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-01-2012, 10:46
FRC #2972
Well we got it working, it turns out Windows 7 has 3 different firewall profiles and the public one was still on, which is what our connection was designated as. All I can say to you Mr. Lim is that you make sure all three profiles are disabled. Each profile has it's own tab in the firewall settings.
Unread 19-01-2012, 20:37
AKA: Mr. Lim
Thanks!
MKoval in another thread suggested this command as well:
netsh advfirewall set global StatefulFTP disable
Both solutions appear to be good.
