Go to Post You don't have to build a winning robot to build a team, but you won't build a great team unless they are striving to build a winning robot. - Richard Wallace [more]
Unread 18-01-2012, 22:24
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Re: 2785 Drive Train- Border Hopping Capabilities
Definitely load it up like everyone else said. But more importantly make sure you test everything on carpet as well. I hate to see teams go into competition with long base four wheel drives and have to either switch one set to slick wheels or omnis because they just can't turn. It looks like you have moved the wheels closer together. This may help some but I doubt it will be enough.
Keep up the good work otherwise.
Unread 18-01-2012, 22:28
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
Don't forget about bumpers... they have to be at least 2 inches from the floor. this makes your plans a bit difficult...
Unread 18-01-2012, 22:35
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
I don't see how this has a problem with the bumpers, the bottom of the bumpers may be mounted from 2"-5" from the floor.
Unread 18-01-2012, 23:09
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I'll mirror the above comments: load the robot with some weight, on carpet, and then try.
We did this today and it couldn't make it over with the 8'' 2011 wheels (with extra c-channel to provide a 1 inch lift).
Unread 19-01-2012, 10:36
kamikazejoshua kamikazejoshua is offline
FRC #3793
kamikazejoshua is an unknown quantity at this point
What is the height of the bottom of your frame above the floor?
Unread 19-01-2012, 10:50
gman892's Avatar
gman892 gman892 is offline
#2785
FRC #2785
gman892 is an unknown quantity at this point
The Center of the frame is 7" above the ground.
Unread 18-01-2012, 22:33
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Why 80/20? Our team has used the kit aluminum for the last 6 years and never had a problem with it. It's loaded with holes for mounting, and lighter than the extruded 80/20. The only time it bent was in 2005 when we didn't use bumpers (ahhh the good ole days).
Omni's are a good way to go for front wheels and easy turning in 4wd. Otherwise, the kit frame is really easy to adapt a 6 wheel drive. Just make sure your center wheel is 1/8" drop.
Cold Fusion's 10th Season
