Go to Post Only on CD would people debate calculus problems involving time and team numbers... - artdutra04 [more]
Unread 18-01-2012, 22:33
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: 2785 Drive Train- Border Hopping Capabilities
Why 80/20? Our team has used the kit aluminum for the last 6 years and never had a problem with it. It's loaded with holes for mounting, and lighter than the extruded 80/20. The only time it bent was in 2005 when we didn't use bumpers (ahhh the good ole days).
Omni's are a good way to go for front wheels and easy turning in 4wd. Otherwise, the kit frame is really easy to adapt a 6 wheel drive. Just make sure your center wheel is 1/8" drop.
Cold Fusion's 10th Season
