Go to Post I don't see why this is an issue. Robots are immune to the N1H1 virus. - JesseK [more]
  #196   Spotlight this post!
Unread 19-01-2012, 00:12
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Banebots RS-775 Case Short
Originally Posted by Chris is me View Post
So you have non-metal pinions and screws on your motor? To me it seems VERY hard to electrically isolate a 775.
Not at all hard, just requires a judicious application of non-conducting materials. In our 2011 robot it happened by accident. In our 2012 robot it happened by design.
In this picture are the two from our 2011 robot. They are both mounted to wood and are chained to an axle supported by plastic (rulon) plain bearings. They have worked flawlessly through driver training, a Week 0, GSR to 3rd semi-final match, Palmetto to 1/4 finals, and many more hours of demos.
http://i.imgur.com/iPZAZ.jpg
Here is a picture of our prototype shooter, the motors and everything metallic they are connected to are mounted in lexan plates, no problem.
http://i.imgur.com/b018x.jpg
  #197   Spotlight this post!
Unread 19-01-2012, 00:33
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
rather nice prototype you got there!
  #198   Spotlight this post!
Unread 19-01-2012, 01:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Not that I am trying to sell Banebots, but I have it on good authority that the source of the shorted motors is no longer supplying parts to Banebots.
If so, that's a step in the right direction for BaneBots' customer service.
But do you think you could prod FIRST to take official notice of this fact, and clarify their position on the legality of the different motor types, and their specifications? (As is, depending on the particulars, it could be a repeat of BaneBots' mystery motors from 2009—we never did find out what the plastic-endcapped motors were, or what FIRST thought of them.)
  #199   Spotlight this post!
Unread 19-01-2012, 13:38
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Got an order of RS-775 motors in today, and this is what I saw when I opened the box. Doesn't exactly make me encouraged about their quality control, when the motors aren't even securely packed and are rattling around inside the box. I'll report back once I've had a chance to test them tonight.
Jeff Waegelin
  #200   Spotlight this post!
Unread 19-01-2012, 14:47
El Jefe de 148
Update: Art and I tested the whole shipment - we had 3 out of 16 motors with case shorts. It's an improvement from last year's results, but still much worse than I'd consider acceptable.
Jeff Waegelin
  #201   Spotlight this post!
Unread 19-01-2012, 14:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I guess that's why we are pretending they don't exist. Thanks for the data.
  #202   Spotlight this post!
Unread 19-01-2012, 15:15
Brandon Holley's Avatar
Ughh.
Thanks for the update Jeff.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #203   Spotlight this post!
Unread 19-01-2012, 16:31
Chris is me's Avatar
AKA: Pinecone
Amen to that. No Banebots at all costs here.
  #204   Spotlight this post!
Unread 19-01-2012, 16:54
AdamHeard's Avatar
Lead Mentor
The 550 motors, p60 line of gearboxes and Cimulator are all great products; unsure as to why you'd avoid them at all cost.
  #205   Spotlight this post!
Unread 19-01-2012, 16:59
AKA: Pinecone
It's more of an ethical issue than a practical one - if they have crappy 775s and continue to ship them out, I don't trust their quality control overall when I have reputable companies with better service to supply me with motors.
  #206   Spotlight this post!
Unread 19-01-2012, 17:01
Might I ask: do all the motors appear to be identical? Or does it look they are not all made by the same manufacturer...
  #207   Spotlight this post!
Unread 19-01-2012, 17:11
artdutra04's Avatar
VEX Robotics Engineer
[i]Might I ask: do all the motors appear to be identical? Or does it look they are not all made by the same manufacturer...
All of the Banebot RS775 motors we have (both existing ones from 2011 and the recently arrived ones from 2012, including both case-shorted and non case-shorted motors from both years), look completely identical. They both even have exactly the same writing printed on them:
RS775WC-8514
DC18V/CCW
in the exact same location on the flux ring.
The only difference is the 2011 motors were shipped with an orange Banebots sticker on them.
Edit: If Banebots did supposedly switch to a new supplier, I'm wondering if these are the remainder of old motors from last year they had in stock?
Art Dutra IV
世上无难事,只怕有心人.
  #208   Spotlight this post!
Unread 19-01-2012, 17:13
Best Available Data
FRC #1778 (Chill Out!)
If all the Styrofoam is in the box, how do you know BB is at fault? Shipping companies don't intentionally damage goods, but they move a truly monumental number of packages and occasionally stuff gets dropped/run-over/what have you.
  #209   Spotlight this post!
Unread 19-01-2012, 17:14
AdamHeard's Avatar
Lead Mentor
That's four very high power motors your skipping out on for your robot (the 550s).
  #210   Spotlight this post!
Unread 19-01-2012, 17:30
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
"Fool me once shame on you, fool me twice shame on me."
A lot of teams are naturally gun shy about these motors because of the huge failure rates teams saw last year. I'm not surprised at all that some teams are taking a "better safe than sorry" attitude when it comes to the 775's. Much like most things in life, it comes down to the risk to reward ratio. Is the higher power available from the 775's enough to justify the risk of my robot having severe electrical issues? Each team's decision will be based on just how risk adverse they are and how high of a risk they view the situation as. I know on 1114 we'll be giving these motors another chance, but at the first sign of trouble they'll be introduced to our arbor press.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
