Go to Post "its not working because you didnt program it right" *wheel falls off* "never mind" - Nin_estarSaerah [more]
Unread 19-01-2012, 00:15
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Deploying Java via NetBeans on the driver station PC fails
Originally Posted by mkoval View Post
We're using Java, which does not depend on LabVIEW and it works fine from my personal computer. In any case, we do have the latest version of LabVIEW installed.
I provisioned the cRIO yesterday with FRC_2012_v43.zip. As far as I can tell, this is the latest version of the firmware.
Can you FTP to it? Because we had the exact same problem, but everything got resolved after doing all that.
