Go to Post Count on the English teacher to be the one to actually understand the wording of the rules! - dlavery [more]
Unread 18-01-2012, 23:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Varying Regulator Pressure Using Mechanical Device
Just curious what the CD brain trust thinks of the idea -- and whether it is a legitimate method of interfacing with pneumatics components. The rules don't seem to outlaw it, but pneumatics have always been something of a sacred cow and so I'm nervous about pushing the envelope too much.
In short -- we'd like to vary the force a pneumatic actuator exerts by varying its operating pressure. In order to do that, we're imagining that we'll mechanically drive a pressure regulator. There'll still be a 60psi regulator as required, but this secondary regulator will allow us to reduce the working pressure to one or more actuators dynamically.
Thoughts on its legality? Has anyone tried this before? Are we insane? Yes is an okay answer.
--Madison--
...down at the Ozdust!
Unread 18-01-2012, 23:53
AdamHeard's Avatar
Lead Mentor
Re: Varying Regulator Pressure Using Mechanical Device
I see no reason as to why it'd be illegal.
Unread 19-01-2012, 00:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
http://www.chiefdelphi.com/forums/sh...ad.php?t=80658
http://www.chiefdelphi.com/forums/sh...ad.php?t=72464
http://forums.usfirst.org/showthread.php?t=11220
As for this year, I don't see anything that would make it illegal, as long as you could show that the upper limit was always respected.
Unread 19-01-2012, 00:24
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
You could have multiple one way solenoids, each with its own regulator. Any weirdness could be fixed in code.
The way it would work is that you use multiple single function solenoids (or just a standard two way with one output blocked) to feed air into the solenoid and one solenoid as an exhaust. This setup would have to be repeated per function (in, out, etc). It would be ugly, but it would work.
If you find a way to reliable change air pressure I would like to know
A bit of googleing (yes... google as a verb) found these (http://www.smcetech.com/CC_host/page...6669613456b3f5)
They are electronic regulators, don't know if they are good for a robotics aplication, but it would be interesting to try.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 19-01-2012, 00:44
RoboDawg's Avatar
RoboDawg RoboDawg is offline
AKA: John Kaessinger
FRC #2130 (Alpha +)
RoboDawg has a spectacular aura aboutRoboDawg has a spectacular aura about
I agree with Tristan, I see no rule violation if you keep everything under the 60psi rule. Bummed we wont see X bot at Portland. Good luck, 2130)
Unread 19-01-2012, 01:50
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
We did exactly this in 2010 to vary our kicker distance. We used a window motor with the black plastic connector that comes in the kit to control a secondary black Norgren regulator remotely via the drivers. We had a pressure transducer connected to report the pressure back to the drivers station which had a graph calibrated in distance. The coupling between the black plastic window motor thingy and the black Norgren regulator was a simple piece of automotive heater hose about 2" long. It worked great and required no modifications to any pneumatic components. We coded safety stops in the software to stop the window motor at something like 20PSI one way and 55PSI the other way so a trigger happy driver couldn't break the knob off the regulator. Photos available upon request...
Unread 19-01-2012, 02:46
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
servo?
Unread 19-01-2012, 08:04
Madison,
There is currently no rule that would prevent it. When this discussion came up a few years ago, we all did some searching and found several electrically operated regulators. Unfortunately most were designed for AC 24 volt controls. While we expected many teams to jump on the band wagon, we actually saw very few in inspections. I don't remember seeing any on the robots I inspected. I am going to guess that was due to either cost, complexity of control or additional weight. I know one team showed a servo attachment but the servo was not legal under FRC rules at the time. Please remember that all other rules still apply and one of those is the ability to release all stored pressure through one pressure relief valve.
[R77]
The pressure vent plug valve must be connected to the pneumatic circuit such that, when manually operated, it will
vent to the atmosphere to relieve all stored pressure. The valve must be placed on the Robot so that it is visible
and easily accessible. If the compressor is not used on the Robot, then an additional vent valve must be obtained
and connected to the high-pressure portion of the pneumatic circuit off board the Robot with the compressor (see
Rule [R73]).
Unread 19-01-2012, 13:38
Madison,
Wasn't there a potential problem with the electric regulator containing a non-KOP motor?
Unread 19-01-2012, 14:10
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I would setup the adjustable regulator downstream of the fixed 60psi Norgren regulator, to ensure nothing cause your pneumatic components to operate over 60psi.
Unread 19-01-2012, 14:43
I meant to add that the Q&A is the only official answer on the use of items not listed in the rules. I am not the GDC so my answers are not official.
Unread 19-01-2012, 14:53
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
If you are trying to vary the force / speed of cylinders, there is a trick involving multiple cylinders. Instead of one large cylinder, use several small cylinder in parallel, each connected to its own valve.
To vary speeds: Connect all cylinders to the valves in the normal fashion. High force kick, extend all cylinders. Lower force, extend some cylinders, keep some in retract, these retracting cylinders will "fight" the extending ones, reducing the force and speed. A cylinder has more force in extend than it does in retract, so as long as you have as many or more cylinders extending than retracting, it will extend. If you use four cylinders, that will give you three different extend speeds / forces. We did this in 2010 (we also used surgical tubing to help extend, so we could actually extend with all but one cylinder in retract)
Former Mentor Team 1771
Former mentor Team 4509
Unread 19-01-2012, 21:16
hocman22 hocman22 is offline
AKA: Mike
Team Role: Student
hocman22 is an unknown quantity at this point
So with the link you posted..... is it possible to program it to fire a cylinder at different pressures?
Can we take a shot at 60 psi, then go to 55psi on the next one then drop to 30psi?
Unread 19-01-2012, 23:14
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
I think Rule R78 would pretty much put this scheme out to pasture:
R78--The outputs from multiple valves may not be plumbed together into the same input on a pneumatic cylinder.
As an inspector, I would take a careful look at anything like you suggest.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 20-01-2012, 00:10
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Varying Regulator Pressure Using Mechanical Device
All the cylinders that we have used in the past have an adjustable valve that allows you to adjust actuation speed/force manually. You should be able to design a servo- operated link to this valve knob to adjust the applied pressure. The servo has a built in encoder, and use a continuous rotation type. Some years we were only allowed to use certain servos, all of which had limited rotational capability (180 DEG. or less). check this year's rules on servos that are allowed. they are usually very specific on maximum torque and capability specs.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
