Go to Post I love our bot. I think I want to take it to prom...:D - prettycolors91 [more]
Unread 18-01-2012, 22:03
mkoval's Avatar
mkoval mkoval is offline
AKA: Michael Koval
FRC #4281 (Bulldogs)
mkoval has a spectacular aura aboutmkoval has a spectacular aura about
Deploying Java via NetBeans on the driver station PC fails
We're having uploading code to the cRIO from NetBeans installed on the driver station netbook. Uploading fails with this warning, followed by a Java stack trace regarding the failed connection:
Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC: address: 10.42.81.9 netmask: 255.255.255.254
WARNING: Host is not on same subnet as robot. May not be able to complete all communication with robot.
Note that the subnet mask is being printed as 255.255.255.254 and it should be 255.0.0.0. This doesn't make much sense, because ipconfig and the Control Panel both show the subnet mask being set to 255.0.0.0.
I can transfer code to the cRIO from my personal laptop (that is running OS X), so it is not an issue with the cRIO or wireless router. I believe it's either an a problem with the computer's network configuration or the NetBeans plugin. I have already verified that our team number is set in NetBeans, verified that the compiler plugins are up-to-date, and have disabled IPv6 on both wifi and ethernet. Any suggestions?
Unread 18-01-2012, 22:50
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Re: Deploying Java via NetBeans on the driver station PC fails
The "incorrect" subnet should not cause a total failure. You might never get rid of that warning; it's generally a bug.
I'm not sure why you can't connect though. A few restarts of the classmate/netbeans and the robot, with some confirmation of the network configuration seems to clear up the failure for me. I can't explain why.
Unread 18-01-2012, 23:02
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
As nickpeq said, that error shouldn't cause it to completely fail. We get that error every time, but it still works.
What error are you getting after that? Just cannot connect to the cRIO... failed after x attempts...?
Unread 18-01-2012, 23:52
mkoval's Avatar
AKA: Michael Koval
It's good to know that the warning is a known issue.
Immediately after the warning I get a Java stack trace caused by an uncaught SocketException. I don't have the full stack trace on hand (not that it contained much useful information), but I'll post it next time I have access to the cRIO.
Have you ever encountered something like this?
Unread 19-01-2012, 00:05
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Did you install the latest Labview? This was our issue. Also the latest firmware on the cRio. Try FTPing to it manually by putting
ftp://10.42.81.2
into a windows explorer window. If it connects, your configuration is good. Just get the latest labview and utilities updates.
Unread 19-01-2012, 00:13
mkoval's Avatar
AKA: Michael Koval
We're using Java, which does not depend on LabVIEW and it works fine from my personal computer. In any case, we do have the latest version of LabVIEW installed.
I provisioned the cRIO yesterday with FRC_2012_v43.zip. As far as I can tell, this is the latest version of the firmware.
Unread 19-01-2012, 00:15
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Can you FTP to it? Because we had the exact same problem, but everything got resolved after doing all that.
Unread 19-01-2012, 00:20
mkoval's Avatar
AKA: Michael Koval
Do you mean manually FTPing (e.g. ftp 10.xx.xx.2) from the driver station netbook to the cRIO? It is definitely possible to FTP from my personal computer to the cRIO because it is part of a normal deployment. If that's what you mean, I'll try manually FTPing next time I have access to the robot.
Unread 19-01-2012, 02:48
AKA: Brad
#0190 ( Gompei and the Herd)
Can you try turning off the windows firewall temporarily to see if that fixes the problem?
Brad
Brad Miller
Robotics Resource Center
Unread 19-01-2012, 05:13
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Run a command line (type "cmd" into the search bar in the Start Button), and see if you can ping the cRIO.
ping 10.42.81.2
Getting a response will at least ensure the network itself is working fine.
If you get a ping, and still can't successfully send code, disable your firewall, and/or make an exception for NetBeans.exe.
If that still doesn't work, you might be experiencing this:
http://www.chiefdelphi.com/forums/sh...hreadid=100588
For which I personally am still stumped by, and don't have a solution.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-01-2012, 15:57
mkoval's Avatar
AKA: Michael Koval
I already allowed netbeans in Windows Firewall. i finally fixed the problem by following the instructions in this post on the NetBeans forums. Specifically, run the following command in a command prompt with administrative rights:
netsh advfirewall set global StatefulFTP disable
