Go to Post "PWMed" - Sam N. [more]
Unread 18-01-2012, 14:43
CityAcademy CityAcademy is offline
FRC #4225
CityAcademy is an unknown quantity at this point
Cool How much pressure to lower ramp?
Hello,
We're a rookie team. It might be out there, but we can't find the info for how much pressure it takes lower the ramp. Obviously, when lowering, it is w/out another robot on the ramp. The ramp, as we understand, is approx. 10.5 inches high.
All suggestions welcome.
Unread 18-01-2012, 14:49
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: How much pressure to lower ramp?
idk where you got 10.5 inches...
Each Bridge is 48 in. wide, 88 in. long (outside dimensions), and sits with the top platform 12 in. high off the ground when level.
suggestion:
Read the manual.
Originally Posted by Arjun View Post
H First off, it's been calculated that we need about 16-18 pounds of force to push the bridge down.
cole?
Unread 18-01-2012, 14:50
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
First, a correction. According to section 2.2.5 of the Game Manual ("The Arena chapter), the bridges, when level, are 12 inches off the ground, not 10.5.
As for force, check out the video FIRST posted about the bridges here: http://www.youtube.com/watch?v=-AMaq...eature=related
The use standard FRC batteries in a great demonstration of the tipping point, and you should be able to use that to figure out how much you need to push on it with your manipulator to get it to go down.
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Originally Posted by CityAcademy View Post
Hello,
As started above the ramp is about 12inchs off the ground.
There is already a thread going on about this, search is your friend
But it takes about 16-18lbs of force to lower it from one edge with nothing on it.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-01-2012, 14:55
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
JakeD will become famous soon enoughJakeD will become famous soon enough
900 inch pounds of torque is a reasonably close number and easy to remember.
2 * 15 lbs (batteries * 30 inches* off center = 900 inch lbs.
Some more quick math revels that 900/44 inches from center of bridge is about 20.5 lbs straight down on the bridge. Just remember to round up to be safe.
Unread 18-01-2012, 14:57
Team Role: Mascot
are you referring to the batteries as 15 lbs? because that is a little heavy :/
cole?
Unread 18-01-2012, 14:59
JakeD's Avatar
Easy to remember numbers and safe assumptions.
EDIT: im aware that the batteries are lighter, as well as their center of mass is closer to the 27.5 inch mark on the bridge.
Unread 18-01-2012, 15:01
Team Role: Mascot
I prefer accurate > easy
cole?
Unread 19-01-2012, 07:49
If you want a more accurate number, start with a better estimate of the batteries' weight and location of their center of mass, and remember that the pivot point of the bridge is about 3.5 inches closer to its downward than the actual center.
Unread 19-01-2012, 11:41
dcherba dcherba is offline
FRC #3234 (Red Arrow Robotics)
dcherba has a spectacular aura aboutdcherba has a spectacular aura aboutdcherba has a spectacular aura about
Smile Re: How much pressure to lower ramp?
if you look at the videos they talk about the force to balance the ramp. It takes about 760 in-lbs based on the two batteries used. If you work that out for the 44 inches to the end of the ramp that is about 17 lbs.
Dave Cherba
Mentor Team 3234
WZ8T
