Go to Post It really is up to us to stand up for these principles so when we sell it to the general public we're not just feeding them some line because if we don't believe it, why should they? - Koko Ed [more]
Unread 16-01-2012, 21:17
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Hall Effect Latch as an encoder/counter?
Hello -
I have been looking at other methods to count rotational speed of a wheel, in this case of a wheel could be spinning at 50+ Hz. Those US Digital KOP sensors have their place, but can be hard to work with if they are not going on a COTS transmission/gearbox with the correct size shaft already available. I am not concerned about direction.
We first looked at the Rotary magnetic encoder in the FIRST Choice parts this year, but that isn't going to work based on the data sheet. It provides angle based on the orientation of the magnet's poles, and I don't think it would be realistic to sample it at a high enough frequency to catch a desired analog value or PWM width.
I had some Melexis US1881 Hall-Effect latches sitting in my bin of goodies and figured they might work as long as their switching speeds were fast enough and they were sensitive enough. We bench tested today with a CIM and two magnets (one north oriented, the other south 180 degrees seperate on the hub). We spun up the motor and got a perfect square wave on the logic analyzer over the whole range of RPMs. The thought is to just pass this output into a digital input, run the wpilib counter and timer functions on it and calculate frequency.
So this brings me to my question - has anyone done this before successfully on a competition system? It seems to work great as a bench test proof of concept. The biggest concern I have is ensuring we mount the magnets safely on the wheel. I looked through the robot rules manual and didn't see anything excluding the use of magnets (in general or in a manner such as this).
Any thoughts (good or bad)?
Unread 16-01-2012, 21:45
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Hall Effect Latch as an encoder/counter?
Excellent example of improvisation!
Unread 19-01-2012, 08:38
Gdeaver Gdeaver is offline
FRC #1640
We are trying a similar device. K&J Magnetics has diametrically magnetized neodymiums that work well. Usually require a pull up resistor.
Unread 19-01-2012, 10:07
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Have you looked into reed switches? We were thinking about using them as limit switches -- that way, we could directly connect them to the jaguar's limit switch pins.
Unread 19-01-2012, 10:12
Iam,
There doesn't seem to be any rule that would prevent this application. I would tender that answer with a caveat to insure that magnets do not come loose on the wheels. Traversing the barrier is going to put a lot of stress on wheels and typical plastic hubs will take the brunt of the shock causing deflection and breakage. Should your magnets find their way into a competitors robot during competition, there could be nasty results. While the hall effect sensors meant for the transmission are difficult to use, they do produce significant resolution when used on the high side of the reduction.
Unread 19-01-2012, 10:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That sounds like a neat way to do it. I didn't know they made such a thing as a Hall-effect latch.
http://search.digikey.com/us/en/prod...1EUA-ND/431867
(obviously we're trying to figure out how to do the same thing you are!)
Unread 19-01-2012, 21:26
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
BitTwiddler is on a distinguished road
In 2009 we used one of these on our turret.
http://search.digikey.com/us/en/prod...2021-ND/701375
It's designed for counting gear teeth but any ferrous material passing by it will trigger a detection. We counted the number of times a screw head mounted on the end of our roller/shooter would zip by the sensor.
Unread 19-01-2012, 21:46
FRC #1640
Our programmers are having trouble with the timing concept but have it for distance traveled. Have not tried it for the shooter. May go the analog route for the shooter.
Unread 20-01-2012, 17:57
MrForbes's Avatar
AKA: Jim
I ordered a couple of the latching hall effect sensors to play with.
Unread 20-01-2012, 21:11
FRC #2729 (Storm)
Squirrel - that's the part I have had good luck with. I got it from sparkfun.
Al - We are looking to use this on a flywheel (hint hint). So I hope it won't take as much abuse as a drive-train wheel, but it will be spinning faster so loose parts would be even more dangerous. If we can't be sure we can attach safely we will certainly abandon the idea for this application.
As for a reed switch. I have never used one. They contact due to magnetic field detection, but it is a mechanical motion right? So I was concerned about lifespan (how many times are they design to switch) and switching speed. I am certainly curious if someone thinks they can work for this as well.
I really like the looks of that Honeywell sensor mentioned above. That's a pretty steep price compared to the hall latch (under $1), but if it provides a simple and stable solution it's certainly worth trying out.
I love FRC build season - it really gets the brain going non stop!
Unread 21-01-2012, 08:49
FRC #1640
We put a 1/2 x 1/8" N52 neodymium magnet on the end of our shaft and get good readings out to 3/8" gap. Good non-contact sensing device.
Unread 22-01-2012, 09:26
Reed switches might work for your application but they are notorious for generating noise (contact bounce) so you need to take appropriate steps for accurate readings.
Unread 25-01-2012, 07:38
FRC #2729 (Storm)
FYI - I have done a PCB layout using expresspcb.com's service and the boards should be in tomorrow. If all goes well we are considering ordering a larger batch to sell kits/assembled units for those not 'in the market' of developing their own sensors. Would anyone be interested?
Unread 26-01-2012, 21:49
FRC #2729 (Storm)
And here is the assembled and functioning PCB. It is about 1.75"x.75". Hope it works out our pitcher this year! I used expresspcb.com's SW to do the layout and used their protoboard service for the board manufacturing.
We have not tried interfacing it to SW yet, I hope to on Saturday.
squirrel - If you don't mind me asking - was your team able to use encoder lib calls from WPI or did you have to build your own timer/counter algorithm for the hall latch?
Unread 26-01-2012, 22:43
MrForbes's Avatar
AKA: Jim
I don't know of having got that far yet, we got the sensor wired up and working but haven't actually tested it with running motor...hopefully first thing tomorrow afternoon we'll get working on it, since we finally got the new shooter (with a place to put the sensor and magnet) put together tonight.
