Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 19-01-2012, 08:43
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: how much current does jag use
As a second hint, when crimping terminals, always perform a 'tug test'. That is to say after you crimp a terminal to the wire, pull on the terminal as hard as you can. If you can't pull it off, it should be good. If you do throw it away and try again.
When I teach the tug test to students: "Well if it comes off, you have to redo it anyway"
Also make sure you are tugging hard enough. If you can get to arm shaking level while tugging, then it is ready for competition.
My last crimping hint is to buy a good crimper. The one that comes in the kit is functional, but it's harder to make a crimp that passes the tug test. something like Mcmaster #69555K62 is 10 times better than something like #7007K92.
@Al, Are wire ferrules (7950K28) in the terminal blocks allowed? I don't see anything in the rules one way or the other.
