Go to Post Speculate away! - IndySam [more]
Unread 19-01-2012, 09:49
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Wiring for a Turret
Ok all -
What would you recommend as the best way to wire a 360degree turret. While we could use a slip-ring, its pretty expensive. Any suggestions?
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 19-01-2012, 09:57
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: Wiring for a Turret
You can always make your own slip ring, But that requires an extensive amount of machining and well becomes complex very quick.
The slip ring allows for unlimited rotation without snagging.
If you were to use wires conventionally you can have it so it has over 360 degrees of freedom depending on how you run it. This would help a lot if you wanted that ability.
Its hard to conceptualize in words maybe someone else can do that?
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 19-01-2012, 10:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We had a 180ish turret in 2009, and just had a "mast" behind it that brought the wires up, and they then draped over to the top center of the moving part.
You could also try to use the plastic "chain" thing somehow, from the igus bag in the KOP.
I'm trying to convince our students that we don't really want the turret to move anymore than absolutely necessary to do the final aiming...something about having too many degrees of freedom...let alone the mechanical problems such as this that it creates
Unread 19-01-2012, 10:07
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Any way to alter your design in order to not need a wiring harness above the pivot point? Think abstract!
Unread 19-01-2012, 10:15
I would be remiss if I did not remind everyone that COTS slip rings may not contain mercury under the hazardous materials rule R08.
Unread 19-01-2012, 10:23
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
In 2008, 190 made a slip ring out of polycarbonate tubing, copper bands, and the brushes from the inside of a few hand drills.
Unread 21-01-2012, 08:55
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
We could always convince a large Slip Ring producer to make slip rings specific to FRC cost and size restraints. It would be good for business. Otherwise I will just get them to sponsor us.
Unread 21-01-2012, 09:35
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
This is true. The driver ought to be able to get within 30* of the goals - if there is an onboard camera, then within 15* without much difficulty; having a turret with 60* of turn ought to be more than sufficient.
Having lots of slack wire to compensate for a turning mechanism can be dangerous. In the past when we've had telescoping parts we've used coil tubing found on air compressors. The coil would stretch when extended then return to a coil when retracted.
(I almost used the example of a telephone cord, then I realized there may be quite a few people here who don't know what that is/was.)
Hi!
