Go to Post What's this about a robot that they speak of? Are we supposed to build one???? - ryan_f [more]
Unread 17-01-2012, 15:45
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Where to get two-pin connectors
I'm look to buy those cables that are like PWMs, but are 2-pins. Where can I get them? AndyMark doesn't seem to sell them
Unread 17-01-2012, 16:03
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
Re: Where to get two-pin connectors
Try http://digikey.com, part number: WM2800-ND
Unread 17-01-2012, 16:14
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
You could cut off one connector of a PWM cable, but the best solution is to make your own. The best prices I've found are at www.hansenhobbies.com and we've used them many times. Terminals and housings are here. The economy wire here is just fine, no reason to buy the deluxe wire. Unfortunately they only have 3-conductor wire, you can either peel off one of the conductors or just wire you got from somewhere else. Make sure you use wire that meets the size requirements of the manual (24 AWG for most uses). The crimping tools are here, again, no reason to get the deluxe one, the economy one works great
Jason
Unread 19-01-2012, 10:13
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Another vote for Hansen Hobbies. Team 95 has several Hansen Hobbies crimp sets floating around that we use to make custom cables of the right length.
Unread 19-01-2012, 10:20
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
If you need something quick and dirty to get yourself up and running, check out a junk PC. Many times they use these connectors for fans or to connect indicator lights to the mother board.
This is the zeroth day of the rest of your life.
