Go to Post No matter what the weight limit is, a large number of teams will *ALWAYS* have trouble making it. - Cory [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2012, 16:39
hips dont lie hips dont lie is offline
FRC #1539
hips dont lie is an unknown quantity at this point
Question Fishing Rod for our Launcher
Is there anything in the rules that says that we can or cannot use a fiberglass fishing rod as a throwing arm on our robot.
Unread 18-01-2012, 16:41
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Fishing Rod for our Launcher
As long as it's not unsafe, and it costs less than $400 then yes.
Unread 19-01-2012, 09:29
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
If you want to build a spring powered catapult you might want to consider a section of a cross country ski, or toy bow and arrow as sources of material. Both can usually be found cheaply at many goodwill stores. We prototyped such a launcher and it can be made extremely accurate and reasonably powerful. Our students really want to do a reaction wheel, but I think that is more weight and complexity than required. Take a look at the soccer kicker that the robowranglers did a few years back for ideas. They used a simple cam to control the spring.
http://www.youtube.com/watch?v=_hTyXQUgYLE
This is the zeroth day of the rest of your life.
Unread 19-01-2012, 10:23
Of course it must fit inside the size and weight constraints and be listed on your BOM at cost. However, since fiberglass has a tendency to fracture, you may be called for having an unsafe mechanism.
Unread 19-01-2012, 11:05
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I saw a couple of teams try that approach in "Breakaway", using a V-shaped apparatus to try and launch a hanging hook onto the tower. Many found that they had significant control issues when they released the poles, since they would tend to twist when they were released. I would guess the size and weight of a basketball would magnify that issue.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 19-01-2012, 16:22
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
What we've used before was some thin diameter (I can't remember the exact measurement) PVC tubing. We did that in 2010 in an attempt to fling a hook up to the bar to hang. It'd be pretty cheap, and if you're looking to rapidly prototype, then it'd be convenient until you find a better material.
Academic Student (Forever)
