Go to Post Making GP a rule would be the equivalent of making a law that says you have to help get kittens out of trees. - Molten [more]
Unread 17-01-2012, 19:43
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
HammadB will become famous soon enough
2 motors with different speeds in one Gearbox
What is the rule for using motors with different free speeds on the same initial reduction, how close should they be? Should anything else be considered? Thanks.
Unread 17-01-2012, 19:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: 2 motors with different speeds in one Gearbox
If they are within 10% free speed, you should be ok, however also take into account some motors do NOT like being run slowly - most of your 550 and FP motors have an extreme dislike for it and may smoke.
Unread 17-01-2012, 19:55
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 2 motors with different speeds in one Gearbox
You should be more concerned with matching the torque curves than free speed. If not close, one motor will work against the othe, and reduce power.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-01-2012, 20:04
If you gear to match free speeds, both motors will be producing torque in the same direction over the full range of voltage.
If you gear to match stall torques, then above a certain speed one of the motors will be acting as a generator and will absorb power from the other motor.
Unread 19-01-2012, 13:02
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
An old thread goes into more detail:
http://www.chiefdelphi.com/forums/sh...4193#post24193
Unread 19-01-2012, 13:49
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Excellent point.
And there are lots of options now to match CIMs with other motors that are legal this season and vice versa.
Unread 19-01-2012, 14:07
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
When using mismatched motors, at some point in the speed range, one or the other motor will be backdriven by the other. As a mechanical guy, I have to ask the question to the electrical guys: What is the effect on typical motor drivers (such as the Jags) of having a motor being back driven and acting like a generator when the driver is trying to turn it the other way?
I suspect the short term effect isn't catastrophic, as under-geared robots get pushed backwards quite often. But, I suspect that having this happen continuously, as might happen in a mismatched motor system, might cause something to overheat and fail.
Anyone know?
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 19-01-2012, 14:09
waialua359's Avatar
AKA: Glenn
Anyone know?
We did have some issues running a CIM FP Andymark Shifter (any series) over a repeated use of time. The FP finally gave out after 4 tournaments though.
Unread 19-01-2012, 18:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There is nothing all that magical in this.
For motors with similar power ratings (e.g.250W BB + 340W CIM), the variations between matching stall torques or matching free speeds is not that big of a difference (~5:1 for stall torque, ~4:1 for free speeds). It is not that big of a deal, really.
For my tastes, in high power applications (which is why you want the extra motor isn't it?), I prefer to have the smaller sized (and in the case I discussed power as well) motor do less of the work (so that it will have to dissipate less heat which, because it is smaller is more critical -- heat transfer is a Area X DeltaT thing -- for the same heat to dissipate the less Area the more DeltaT)
In other cases, I only need the more power in one or other of the speed ranges. For drive trains, I think most folks add motors for more torque at low speeds. To that end, I tend to match stall torques. If I give up some speed on the high end, Que Sera, Sera...
Good luck.
Joe J.
Team #88, TJ2
Unread 19-01-2012, 18:43
circa 2002:
Originally Posted by Joe Johnson View Post
This is a very complex issue.
The internet never forgets
Sorry Joe, I couldn't resist!
Unread 20-01-2012, 01:46
HammadB's Avatar
More specifically speaking, since I am unable to get my hands on more FP 0673's is it viable to put one FP 0673 and one RS550 into the same gearbox at a overall reduction between 5~8
Unread 20-01-2012, 02:05
Aren Siekmeier's Avatar
on walkabout
Two different motors do NOT fight. They simply distribute the load and run at a speed according their own characteristics, and you should gear them appropriately to run them at similar speeds, so that one is not doing the brunt of the work (why have two motors?).
Unread 20-01-2012, 10:24
If the 2 motors are geared the same, the 0673 will be working harder (and generating more waste heat) than the 550.
Name:	0673 & 550.png
Unread 20-01-2012, 14:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Anyone know?
Not much. Every time a robot is pushed by hand this happens. It has never damaged any Victor or Jag that I've ever seen.
