Go to Post I jumped up and yelled when I saw both my teams in the same division. Less running for me in the pits. Thank you, Great Homie in the Sky! - Barry Bonzack [more]
Unread 18-01-2012, 19:40
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Surgical Tubing
Originally Posted by Tristan Lall View Post
It didn't seem particularly mean to me.
It wasn't the level of mean that was the issue. It was just the fact that the OP had already been told to read the manual in a quirky manner once. Doing so twice is a bit off-putting. If the "read the manual" statement was followed with something of more substance. I'm not trying to call Don out on this too much. It just seems particularly out of character from him. I'm one that always looks forward to his posts and found this one just a bit disappointing. That's all I have to say about it though as I don't want to single him out any further.
Don, if you have any questions/comments feel free to PM me.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 18-01-2012, 21:10
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Surgical Tubing
So what is the Best way to weld this poly cord stuff together? Mainly what temperature do you heat it to and any other important information about the welding process?
Every day is a new adventure!!!
Unread 19-01-2012, 11:05
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
Re: Surgical Tubing
Zip ties work great, haven't tried welding that stuff, but I assume its possible. You can always try to put an insert into the tube (flexible, of course) and insert that into the two ends of your loop. Rubber adhesive or zip tie crimps should hold that in place.
Home depot has some latex tubing that is pretty much identical to the surgical tubing in the kit. They should have all you need!
Jim, EIT
Unread 19-01-2012, 11:26
dcherba dcherba is offline
FRC #3234 (Red Arrow Robotics)
dcherba has a spectacular aura aboutdcherba has a spectacular aura aboutdcherba has a spectacular aura about
Smile Re: Surgical Tubing
home depot has the tubing for sale in the plumbing department.
Dave Cherba
Mentor Team 3234
WZ8T
Unread 19-01-2012, 14:03
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Re: Surgical Tubing
Joining Surgical Tubing
1. Insert dowel slightly larger than the inside diameter into one end of the tubing about 1.5 inches.
2. Fold back the tubing over itself for about an inch.
3. Remove dowel.
4. Apply contact cement all around the folded back end and about an inch on the other end of the tubing.
5. Allow cement to dry until it is tacky to the touch.
6. Butt the two sides together and unfold the folded end over the nonfolded end.
7. Allow to dry and test.
8. If you need additional strength, you can add some stitching with needle and thread.
Hope this helps.
Unread 19-01-2012, 14:07
riptide's Avatar
AKA: Jeff
Re: Surgical Tubing
Sorry Kevin I just notice you posted the same thing.
Unread 19-01-2012, 14:24
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Surgical Tubing
Yeah so What is the process of welding POLY CORD? Not surgical tubing.
Unread 19-01-2012, 14:44
riptide's Avatar
AKA: Jeff
Re: Surgical Tubing
Well the tread is for surgical tubing but if you insist. They do make kits to do this.
Wear eye protection and gloves as heated poly cord likes to stick and burn.
Joining Poly Cord
1. Cut the cord slightly longer (1/4" for butt joint. 1/2" for splice) than the desired length.
2. For a Butt joint cut both ends perpendicular to the cord.
3. For a splice (stronger) joint cut both at 45 degree angles to each other.
4. Heat both ends until slightly melting. Flame or knife blade solder iron works well. (don’t burn or blacken the cord)
5. Connect both ends together and let cool.
6. Clean up joint with snips and/or sand smoth with fine sand paper.
Unread 19-01-2012, 16:31
thelittlesister's Avatar
thelittlesister thelittlesister is offline
AKA: Ally George
FRC #0316 (LuNaTeCs)
thelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nice
Send a message via AIM to thelittlesister
Re: Surgical Tubing
Back to surgical tubing if anyone is still interested, we make loops by using barbed vacuum line connectors. Lubricate the surgical tubing and connector with rubbing alcohol and let it dry completely. I definitely recommend this, it worked great for breakaway and possibly again this year!
Unread 23-01-2012, 13:57
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: Surgical Tubing
What does the rubbing alcohol do for the surgical tubing, make it grip better to the rollers?
What sort of surface do you need for the rollers when using the surgical tubing?
I have not had much luck with smooth surfaces like PVC and found paint rollers over the PVC seem to work better...
Unread 21-02-2012, 14:00
3640ginger 3640ginger is offline
FRC #3640
3640ginger is an unknown quantity at this point
Re: Surgical Tubing
is there anything that we cant really use surgical tubing for? i know weird question but still. thank you
