Go to Post "We'll fix that in programming" - EStokely [more]
Unread 19-01-2012, 15:49
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Re: Defending the bounce pass
Originally Posted by T Wallas Pog View Post
The balls can be bounced through the lane and over the opposing bridge so unless the other team doesn't have a defensive bot they can get it around that bot every time. However during the first part of the match in the seconds right after Hybrid mode you could start to block against any balls you had scored without fear of interference.
That point (the edge of the flat bridge) is 8 inches higher. I'm thinking that it will be much harder to do. That most successful bounce passes are going to go through the slot between the bridges. In my practices, that was certainly how it worked out. Say a third as many successful passes. Remember every failed pass is a free slam dunk for the opponents (not really, but you get the idea)...
Unread 19-01-2012, 15:54
T Wallas Pog's Avatar
T Wallas Pog T Wallas Pog is offline
FRC #2993 (Megabots)
Team Role: Driver
T Wallas Pog is an unknown quantity at this point
It is indeed higher however I said this because my team was very successful at getting the ball over the bridge by bouncing it. We had about a 5% fail ratio.
Unread 28-01-2012, 23:15
bob1182 bob1182 is offline
bob1182 is an unknown quantity at this point
Were they standing behind the starting line 4 feet from the wall when they did it ? Rule G33
Unread 01-02-2012, 16:36
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
jon-s is an unknown quantity at this point
I think a lot of the defensive capability of the defending robot depends on the shooting trajectory of the offensive/passing robot.
Jon. S
Unread 01-02-2012, 16:40
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
ALL top tier teams with a practice field will be making these consistently. I say this based on personal experience with the field set up in the legal configuration.
