Go to Post I don't think [Amanda] will have any trouble with Needel or the Kelsos but... I can understand Grady and we do have visible evidence of the menace that is Jessica Boucher. (just ask Billfred) - Al Skierkiewicz [more]
Unread 19-01-2012, 11:18
calzim calzim is offline
FRC #2429
calzim is an unknown quantity at this point
Is it possible to slow the piston
Is there a way to slow down the release speed on a piston? Is is all or nothing? We want the piston to expand slowly with less force.
Unread 19-01-2012, 11:22
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Is it possible to slow the piston
If you put a restrictor fitting on the "vent" side of the piston, it will move more slowly with less force. You can also try adjusting the pressure regulator to use less than 60 psi, but the solenoid valve probably needs at least 20 psi to function properly.
I dont know if the restrictors are still included in the KOP, they used to be several years ago. The just have a screw fitting that you turn in to slow the flow of air.
Unread 19-01-2012, 11:37
FRC #2429
any idea who would supply that part? thanks
Unread 19-01-2012, 11:44
MrForbes's Avatar
AKA: Jim
They're called air flow control valve fittings.
http://www.mcmaster.com/#air-flow-co...valves/=fviaym
Parker and others make them.
Unread 19-01-2012, 11:45
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Automation Direct is my preferred supplier for Pneumatic components just because of the massive selection, here's a link: http://www.automationdirect.com/adc/...ed_Controllers
The various speed reducers are on that page, pick the one that best suits your application and you should be good to go.
AndyMark also carries reducers as well, so if you're ordering from them already you can toss one in without too much hassle: http://www.andymark.com/product-p/am-2032.htm
-Dustin Benedict
Unread 19-01-2012, 11:54
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You also recieved a few of them in your KoP this year.
___________________
- Tennyson, Ulysses
Unread 19-01-2012, 12:22
FRC #2429
thanks everyone! have a good build
Unread 19-01-2012, 13:23
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Just remember these valves will slow down the cylinder but will not reduce force. As squirrel said, the only way to reduce force is to reduce the air pressure or use a smaller diameter cylinder.
Unread 19-01-2012, 16:39
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
you can put a secondary pressure regulator on to reduce air pressure, the one to use for that is the one with the yellow ring.
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
