Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Unread 19-01-2012, 11:44
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
CAN jags not working
We are having a strange problem with our CAN Jags. When we enumerate the CAN bus in LabVIEW, all of the Jags register correctly. However, when we tell it to give voltage to a motor, it returns an error that means that the CAN device could not be found. We matched the open motor.vi to the CAN Enum readings, but it didn't work. We know that all of out jags work correctly, as the Ti software was able to drive the motors in a test. Any Suggestions?
Unread 19-01-2012, 11:48
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: CAN jags not working
I had similar issues and it boiled down to not having the driver station enabling the cRIO, even while using the CAN example. If you are already enabling the cRIO, are you using 2CAN or serial? More information will be required, maybe a photo of the test setup?
Eat, Sleep, Build Robots
Unread 19-01-2012, 11:58
Alumni
AKA: David Donahue
we are using serial.
Unread 19-01-2012, 12:12
Alex698's Avatar
Sparky
How long are your CAN cables?
Are you using a terminator on the last jaguar?
What device IDs are you using?
How fast is the loop for CAN? (remember serial is like 1/10th of the CAN bandwidth)
What firmware is on the cRIO and the jaguars?
You can Enum without being enabled, that's why I asked before.
Unread 19-01-2012, 12:55
Alumni
AKA: David Donahue
all but the first are less than 6 in
yes
3 and 11
I don't know
latest firmware
yes, teleop is enabled
Unread 19-01-2012, 17:06
Alex698's Avatar
Sparky
OK, so just to verify:
You have something close to this?
Default 2012 robot project
Begin.vi:
Open2Motor VI -> CAN Jaguar -> Replace PWM drop-down with device IDs -> MotorRef
Teleop.vi:
MotorRef -> Loop[Motor control] -> CloseMotorRef
It may also help to try one jaguar, at a time.
Unread 19-01-2012, 17:13
Alumni
AKA: David Donahue
Yeah, that's what we have. by the way, i forgot to mention that when we try to move the motor, the jag's light blinks quicker.
Unread 19-01-2012, 17:35
Alex698's Avatar
Sparky
What color does the jaguar blink?
If red or green, check to see if there is voltage on the M+ and M- outputs, if not the internal jaguar hardware is bad. The LED will blink because the CAN and PWM interface is isolated from normal jaguar functions in-case of a failure it can keep communication alive.
Unread 19-01-2012, 17:56
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rapidly flashing yellow indicates that the CAN ID is invalid, not that hardware is damaged. Refer to Table 2-2 here for more details.
Have you correctly configured and updated the Jaguars with the BDC-COMM interface?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 19-01-2012, 19:59
Alumni
AKA: David Donahue
Here is a snapshot of the VI that we built to run a motor. the Jags stopped changing the rate of blinking, and are now not showing any indication of being connected outside of Enum.http://www.chiefdelphi.com/forums/at...d=13270212 94
Unread 20-01-2012, 00:26
Alumni
AKA: David Donahue
We are going to use PWM for now, if anyone sees a problem in the test code, please alert me.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 23-01-2012, 09:59
mdonahue mdonahue is offline
AKA: Mike Donahue
mdonahue is an unknown quantity at this point
Thank you everybody for the advice. The problem turned out to be a faulty cRio. We received our new cRios on Friday and everything is working fine.
