Go to Post Does this need a "Do not try this at home" stamp? - sanddrag [more]
Unread 19-01-2012, 19:04
Waltonruler5 Waltonruler5 is offline
FRC #1591
Waltonruler5 is an unknown quantity at this point
Formating cRIO
Our programmer moved last year so nobody on our team understands how to set up everything very well. I'm trying to set up our computer and cRIO but I ran into a problem while trying to communicate. I could get the driver station to recognize the robot code and communication but to make sure I had everything done, I formatted the cRIO. Unfortunately, it only had the FRC_2010_v20.zip folder and now I can't communicate. I downloaded FRC_2011_v28.zip but it doesn't show up under the options for formatting the cRIO. Any help on how to update it would be appreciated.
Unread 19-01-2012, 19:18
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Formating cRIO
The .zip files of the images should be located in C:\Users\<User>\sunspotfrcsdk\cRIO_Images. Also, why are you trying to use v28? (The newest version is 43 IIRC). Is this code from last year or this year?
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 19-01-2012, 19:38
FRC #1591
Re: Formating cRIO
Like I said, not many of us know how to go about this. When I tried to use Netbeans, it told me it was looking for that file. I actually found that I was using the wrong version of the imaging tool. I found the tool from 2011 and it let me use v28 but when I try to format it tells me that a specific file is missing.
C:\Documents and Settings\atrobotics\Local Settings\Temp\lvtemporaryd_178441\cRIOFRC
I checked and the file doesn't exist. I have no clue where to go from here.
Btw, we are not using a classmate computer, so if you could link me to the imaging tool for this year and the necessary files and plug-ins that'd be very much appreciated. Thank you very much.
Unread 19-01-2012, 19:53
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Formating cRIO
Follow the directions here, it is a good place to start
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2012_Assets/Getting%20Started%20with%20the%202012%20FRC%20Cont rol%20System_2.pdf
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 19-01-2012, 20:27
Re: Formating cRIO
The Imaging Tool is part of the Utilities update:
http://joule.ni.com/nidu/cds/view/p/id/2262
If your NetBeans plugins are out of date, they can be installed automatically with NetBeans' plugin interface:
Tools -> Plugins Dialog box -> Settings Tab
If there is an update centre that has the URL http://first.wpi.edu/FRC/java/netbea...te/updates.xml then go on to the next step, otherwise add one:
Add -> Name: Anything, "FRC Java" is descriptive. URL: as above.
In the "Available Plugins" tab if the latest updates are not installed, then six plugins will appear:
FRCRobotTemplates
FRCRenameRefactoring
FRC Java Info
FRCSquawkSDK
FRCApplicationTemplate
FRCCommandTemplates
Click the checkboxes next to those and click "Install". Ignore warnings about unsigned plugins. Once they are installed you will have to restart NetBeans.
tough.exit();
Last edited by Patrickwhite : 19-01-2012 at 20:32. Reason: reinstall netbeans indeed.
Unread 19-01-2012, 20:30
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Formating cRIO
Originally Posted by Patrickwhite View Post
Once they are installed you will have to reinstall NetBeans.
Restart NetBeans
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-01-2012, 21:27
FRC #1591
Re: Formating cRIO
Thank you all very much. I should be able to fix it as soon as I get to school tomorrow.
