Go to Post I don't get what all you people have done wrong to make the drills have so many problems. - Cory [more]
Unread 19-01-2012, 19:02
Spiritor_XYZ Spiritor_XYZ is offline
None #1559
Spiritor_XYZ is an unknown quantity at this point
UDP networking in wpilibj package
We've been struggling with networking code recently, and after finally making a code that works, the wpilibj package does not allow importing java.net. Wondering if anyone has a solution to this problem, because I really dont want to put this to waste. Thanks for any help!
Unread 19-01-2012, 19:26
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: UDP networking in wpilibj package
The cRIO does not run the Standard Edition of Java - rather, it runs the Micro Edition, so projects for the cRIO cannot use java.net, as it is not in the Micro Edition. Some basic networking functionality can be found in javax.microedition.io.
What were you planning on using networking for?
EDIT: Also see com.sun.squawk.io. edu.wpi.first.wpilibj.networktables has some things but I believe they're mainly utility classes for the Smart Dashboard.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
