Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 18-01-2012, 10:10
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
Unresponsive Code... Help Please?
Hello,
This year we've switched to Java. We decided to go nuts and try out the new command based template. I depoloyed our first crack at drive code onto last year's robot with cRio has been re-imaged to the latest. The driver station indicates it has code but the joysticks are unresponsive. Can someone take a look to see if there are any obvious problems?
Here is a link to our Google code repository
http://code.google.com/p/2012-first-...iloctopirates/
The last few lines in Netbeans output window show this:
[cRIO] Default IterativeRobot.disabledInit() method... Overload me!
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
[cRIO] Default IterativeRobot.disabledPeriodic() method... Overload me!
[cRIO] java.lang.NullPointerException
[cRIO] at edu.wpi.first.wpilibj.templates.pleasework.teleopI nit(pleasework.java:55)
[cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:137)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:156)
[cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] WARNING: Robots don't quit!
[cRIO] ---> The startCompetition() method (or methods called by it) should have handled the exception above.
Wendy
Team 3502
Unread 18-01-2012, 10:16
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Unresponsive Code... Help Please?
Originally Posted by twiggzee View Post
Hello,
You never constructed the "Sweeper" object.
Unread 18-01-2012, 14:08
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I haven't looked at the code, but whenever you have a null pointer exception, it usually means you're trying to use something that you, like david said, haven't initialized yet.
Attending: MN Duluth Regional
Unread 18-01-2012, 17:17
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
One the variables referenced at line 55 in pleasework.java is NULL.
Unread 18-01-2012, 17:28
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Instead of:
Sweeper sweep;
It's best to have:
Sweeper sweep = Sweeper.getInstance();
Looking through your code, you don't have any getInstance() methods in Sweeper, which means you may not everything you need to have a "singleton class."
A singleton is a class that ensure that only one instance of it is ever created. The getInstance() method should check to see if a Sweeper has already been created. If it has, return that instance, if not, create a new one.
There are examples of how to make a getInstance() method to ensure your subsystems classes are all singletons. These examples can be found in the WPILib Cookbook.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-01-2012, 12:31
Still no luck, how exactly do you initalize a command? the cookbook says it's supposed to happen automatically when the joystick is pressed...
David, I have this in Sweeper.java. is this not "constructed" as you say:
public class Sweeper extends Subsystem {
Victor sweep;
public void initDefaultCommand() {
setDefaultCommand(new SweepStop());
public Sweeper(){
sweep = new Victor(RobotMap.sweeperMotor);
Since my last post I added a getInstance method to the DriveTrain subsystem as Mr Lim's suggested. I also got rid of all subsystems except for the DriveSystem and the commands pertaining to that just to rule out any conflicts. This includes the Sweeper subsystem and commands.
line 55 in pleasework.java is this, doesn't that need to be there?
public void teleopInit() {
autonomousCommand.cancel();
i commented it out to just to give it a try and it gets rid of the null pointer but still no movement in the robot.
Now, the last few lines in Netbeans' output window show:
[cRIO] teleopInit
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 2 on module 1 is already allocated
[cRIO] at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:t edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive .java:110)
[cRIO] at edu.wpi.first.wpilibj.templates.subsystems.DriveTr ain.<init>(DriveTrain.java:41)
[cRIO] at edu.wpi.first.wpilibj.templates.subsystems.DriveTr ain.getInstance(DriveTrain.java:30)
[cRIO] at edu.wpi.first.wpilibj.templates.commands.DriveWith Joy.<init>(DriveWithJoy.java:27)
[cRIO] at edu.wpi.first.wpilibj.templates.subsystems.DriveTr ain.initDeat edu.wpi.first.wpilibj.templates.pleasework.teleopP eriodic(pleasework.java:70)
[cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:145)
[cRIO] Robot Drive... Output not updated often enough.
Wendy
Team 3502
Unread 19-01-2012, 19:58
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
That error suggests that you are trying to initialize two things to the same PWM port. If all you have left are the drive system and sweeper subsystems, I would hazard a guess that either they are both trying to access PWM channel 2, or that somehow one of them (the one that uses PWM channel 2) is being initialized twice (the sort of scenario the singleton class is meant to prevent). Look through your getInstances to make sure they can only run the constructor once, make sure your constructors are private, and make sure there aren't any accidental calls to constructors outside of the subsystem classes.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 19-01-2012, 20:04
AKA: Mr. Lim
Patrick's suggestion above is a good start.
Also it's possible you are trying to create more than one instance of your Sweeper.
Check your code to ensure you are NEVER trying to create an instance of the Sweeper OUTSIDE of your getInstance() method.
If you have:
Sweeper sweep = new Sweeper();
anywhere else in your code, you need to replace it with:
If you try and create multiple Sweepers by running new Sweeper() more than once, you will get the error error you described. The getInstance() method should prevent that from ever happening.
Unread 25-01-2012, 13:56
Just an update: I found a new version of the cookbook and followed the examples again and it worked this time. Our robot drives now!
The difference was that the previous version of the cookbook was telling us to declare another object (m_drive) in the command file. in the new cookbook that's not there. i took it out of my code and it worked. that would explain why i was getting an error from it trying to access the same PWM port twice...
whew...
Wendy
Team 3502
