Go to Post Maybe it'll be a bumperless year!!! Nah...FIRST likes those things too much... - Fireworks 234 [more]
Unread 19-01-2012, 20:42
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
We got Sockets working
http://www.youtube.com/watch?v=N0xvqxRKCKg
What we have is the computer with the driver station has the PS3 controller connected to it. We then get input from the left stick of the joystick to the CRIO with the regular Joystick Class. Now to send that to the 2nd computer, we use java sockets with the CRIO running the socket server code and the computer running the client socket code. So far, we are just experimenting with sockets with last years robot.
Unread 19-01-2012, 20:51
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: We got Sockets working
Neat!
Your custom dashboard looks a lot like the Smart Dashboard - for what reasons did you decide to make your own, instead of using the Smart Dashboard?
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 19-01-2012, 21:10
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Is that possible to do with SmartDashboard? I'd really love to get those bars for joysticks and the Gyro thing as well!
Unread 19-01-2012, 21:17
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
Wow. I've been trying to lean how to do that in LabView. Since I switched over to java I still wonder how to do that. Could you explain in detail how you got the comms to work?
Absolutely that's possible with the SmartDashboard.
The SmartDashboard package is edu.wpi.first.wpilibj.smartdashboard.
Data sent has a name and a value. The name is used to tie a set of values to a certain widget - if you send "Heading" as 90, then set up a widget to listen to that key, then subsequent sendings of "Heading" will go straight to that widget.
You can send booleans, ints, doubles, and Strings, as well as any class that implements SmartDashboardData. You can even make your own SmartDashboardData-implementing class, though doing so is a bit complicated.
You can make your own widget to display data received any way you like.
tough.exit();
Unread 19-01-2012, 21:22
neal's Avatar
Neal
Oh, cool! I was wondering what putint() and other methods did. But I won't have access to the robot until Saturday. Glad you explained!
How do you make the widgets, though?
Unread 19-01-2012, 22:27
http://firstforge.wpi.edu/sf/wiki/do...iki/Extensions
Great set of tutorials on how to write a widget.
The SmartDashboard itself can be downloaded from the same project, under File Releases.
tough.exit();
Unread 20-01-2012, 09:50
Neat!
Well we are still messing around at this point, but based on how our bot turns out, we will make our Dashboard to fit the bot.
Unread 28-01-2012, 19:25
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Mind sharing how to use sockets im trying to send my vision tracking data to our robot with no luck
Unread 28-01-2012, 20:43
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Might I suggest looking at this thread? It takes away all the little obnoxious parts of sockets and does it for you.
Unread 28-01-2012, 23:44
FRC #0228 (Gus)
Could you possibly share this code because of the lack of examples?
Unread 29-01-2012, 00:10
Programmer
AKA: Joe Grinstead
I would consider using the code provided by WPI.
Unread 31-01-2012, 15:32
FRC #0228 (Gus)
The problem with that is i have a program for vision tracking and it sends out TCP data on its own...
Unread 01-02-2012, 08:35
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Here's one quick example:
// connect to “echo” server:
SocketConnection sc = (SocketConnection) Connector.open("socket://host.com:79");
InputStream is = sc.openInputStream();
OutputStream os = sc.openOutputStream();
os.write("Hello\r\n".getBytes());
int ch = 0;
while(ch != -1) {
   ch = is.read();
sc.close();
Unread 01-02-2012, 08:36
derekwhite's Avatar
More examples here:
http://developers.sun.com/mobility/m.../midp2network/
