Go to Post We treat productive freshmen the same way as everyone else. As for excesively ambitous new people, we have one rule:what happens in the hotel, stays in the hotel... ;) - Crop-Circles [more]
Unread 19-01-2012, 21:18
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
What is the IP address for the new CRIO
We are having issues trying to get the laptop to talk to the CRIO, our Laptop is setup with the IP address of 10.31.79.6, and we try and ping the CRIO using the command prompt and Ipconfig, and we cannot get it to ping. It is not our cable or laptop because we can plug into the old CRIO and it pings out just fine. Are we missing something?
Unread 19-01-2012, 22:03
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: What is the IP address for the new CRIO
I don't believe you can ping the new cRIO's. Your cRIO's IP should be 10.31.79.2
Unread 19-01-2012, 22:14
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I'd guess that the the IP defaults to something like 10.0.0.2. If that doesn't work, change your subnet to 255.0.0.0 and test an IP from each of the three IP blocks defined for private use:
10.0.0.0 - 10.255.255.255
172.16.0.0 - 172.31.255.255
192.168.0.0 - 192.168.255.255
If you get on the right block, the cRIO Imaging tool should then find it, and you're all set.
...let us know what you come up with.
Unread 20-01-2012, 00:16
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
Use the cRIO Imaging Tool. You need to format the cRIO before being able to use it.
Unread 20-01-2012, 07:13
I believe that an unimagined cRIO uses DHCP and zero-config to choose an IP. It is discovered by the imaging tool using the nice, but finicky and slow, nisyscfg that is throwing all of the errors. It is nice because it uses a low level protocol to find and query the devices and build the list.
Greg McKaskle
Unread 20-01-2012, 18:05
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Depending on what software you installed and how you installed it, you may have NI Network Monitor. It helped us determine that our imaging problem was a software problem and not a networking problem.
