Go to Post you know you have overdosed to first when while you are reading all of these things, you can smile and say "oh yeah, i miss doing that" and then, you start to tear up and scream "I MISS FIRST!!!" - amanda547 [more]
Unread 19-01-2012, 21:46
Gdeaver Gdeaver is offline
FRC #1640
Re: Hall Effect Latch as an encoder/counter?
Our programmers are having trouble with the timing concept but have it for distance traveled. Have not tried it for the shooter. May go the analog route for the shooter.
Unread 20-01-2012, 17:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I ordered a couple of the latching hall effect sensors to play with.
Unread 20-01-2012, 21:11
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Squirrel - that's the part I have had good luck with. I got it from sparkfun.
Al - We are looking to use this on a flywheel (hint hint). So I hope it won't take as much abuse as a drive-train wheel, but it will be spinning faster so loose parts would be even more dangerous. If we can't be sure we can attach safely we will certainly abandon the idea for this application.
As for a reed switch. I have never used one. They contact due to magnetic field detection, but it is a mechanical motion right? So I was concerned about lifespan (how many times are they design to switch) and switching speed. I am certainly curious if someone thinks they can work for this as well.
I really like the looks of that Honeywell sensor mentioned above. That's a pretty steep price compared to the hall latch (under $1), but if it provides a simple and stable solution it's certainly worth trying out.
I love FRC build season - it really gets the brain going non stop!
Unread 21-01-2012, 08:49
FRC #1640
We put a 1/2 x 1/8" N52 neodymium magnet on the end of our shaft and get good readings out to 3/8" gap. Good non-contact sensing device.
Unread 22-01-2012, 09:26
Reed switches might work for your application but they are notorious for generating noise (contact bounce) so you need to take appropriate steps for accurate readings.
Unread 25-01-2012, 07:38
FRC #2729 (Storm)
FYI - I have done a PCB layout using expresspcb.com's service and the boards should be in tomorrow. If all goes well we are considering ordering a larger batch to sell kits/assembled units for those not 'in the market' of developing their own sensors. Would anyone be interested?
Unread 26-01-2012, 21:49
FRC #2729 (Storm)
And here is the assembled and functioning PCB. It is about 1.75"x.75". Hope it works out our pitcher this year! I used expresspcb.com's SW to do the layout and used their protoboard service for the board manufacturing.
We have not tried interfacing it to SW yet, I hope to on Saturday.
squirrel - If you don't mind me asking - was your team able to use encoder lib calls from WPI or did you have to build your own timer/counter algorithm for the hall latch?
Unread 26-01-2012, 22:43
MrForbes's Avatar
AKA: Jim
I don't know of having got that far yet, we got the sensor wired up and working but haven't actually tested it with running motor...hopefully first thing tomorrow afternoon we'll get working on it, since we finally got the new shooter (with a place to put the sensor and magnet) put together tonight.
Unread 27-01-2012, 19:57
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
BitTwiddler is on a distinguished road
I like the layout on your board. I suspect the LED is totally superfluous for operational purposes but will be useful in ensuring things are working. Let us know how it works out.
One of our students wired up our prototype sensor board. Its a kludge but it appears to work when we watch it with our handy-dandy voltmeter. More testing will be required. Hopefully the counter vi in the WPI library will work well with it but we aren't there yet.
Unread 27-01-2012, 21:02
FRC #2729 (Storm)
Thanks. Yup the LED is for user feedback only, it tracks the state changes of the output. I dislike that most of the typical KOP sensors have no visual status that they have power and are functioning.
We have 9 PCBs and parts enough to solder them up. Once we are sure the design is working we'll probably make some of them available if anyone is interested, just PM me. If there is interest we can order more boards.
Unread 10-02-2012, 14:13
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
Our team is considering using this as an encoder/counter as well. my concern is that it might not work as well at high speeds.
if, for example, a wheel was rotating at 5000 rpm = 83 rps = 0.083 rp(ms) and the teleop loop runs every 20 ms, then that would mean that the wheel would have spun 1.67 times before the next cycle in the teleop loop. wouldn't that mean that we will miss a revolution every now and then?
by those calculations, the max speed of a wheel that the sensor could measure is 1/20 rp(ms) = 50 rps = 3000 rpm???
on top of that, the hall effect sensor we have is latching meaning it turns on when a north pole passes it and turns off when a south pole passes it (i might have that backwards). so that means it actually has to count twice as fast and max speed of the wheel is only half of that 3000 rpm.
is this the right thinking? i'm kind of new with coding sensors so excuse me if this is totally wrong.
we're using a banebots motor with an enclosed cim-u-later gearbox so we can't mount it anywhere else other than the wheel. we're trying to avoid having another auxiliary gear system just for the sensor (that's why we can't use an encoder).
any ideas on how to get around this in the code? or perhaps a different sensor (other than an encoder)?
Wendy
Team 3502
Unread 10-02-2012, 19:01
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The counting is independent from the loop. The FPGA (hardware) does the actual counting. All your code does is ask it for it's current count. Note that the FPGA can only handle up to ~39000 pulses per second.
Unread 11-02-2012, 08:14
FRC #1640
We have gone to an analog solution. We took a wire coil, some metal and a 12 pole magnet to make an alternator. We get a AC sine wave voltage output proportional to RPM. Next the AC is passed through a full wave bridge and then filtered by a cap and resistor. We then have a nice clean DC voltage that is proportional to the shooter RPM. One of our mentors brought in a scope to check the ripple and we have a nice clean responsive output. Also, the C-rio AD Is -10 to +10 volts. At full speed we are above 5 volts and are taking advantage for the first time of the high resolution that is available. So far it seems to work well. We originally used a small DC brushed motor until we got shot down by the GDC in a Q and A. Hint have you ever taken a stepper apart? There are many advantages to this kind of Tach.
Unread 11-02-2012, 18:16
I'm not familiar with FPGA hardware. Is that something in the digital sidecar or the digital module? How would one access the current count in the code?
Wendy
Team 3502
