Go to Post Now, our team did meet, but there wasn't much inspiring going on. Unless you call pegging me with more darn poof balls exciting. - Paul Copioli [more]
Unread 19-01-2012, 20:19
Jengles's Avatar
Jengles Jengles is offline
FRC #4753 (Bexley Lions)
Jengles will become famous soon enough
2012 Ramp design help
My team is trying to reconstruct the ramp used in this year's competition. Does anybody have the materials needed to build this. We were planing on going to Lowe's tomorrow, so an ordering list would be great.
Unread 19-01-2012, 20:34
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: 2012 Ramp design help
You can find everything you need here http://www.usfirst.org/sites/default...amDrawings.pdf
The parts you need are listed in the image for each drawing
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 19-01-2012, 21:50
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
Don't trust the bill of materials. You will need 4 sheets of 1/2" plywood if you want to include the pinch guards on the sides. At least one of the 1/2" sheets should be of good quality, so the bridge surface stays flat.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Unread 20-01-2012, 11:38
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I second what Mr_D said about the plywood quality... we built ours with 1/2" ply from Home depot and covered it with 1/16" lexan and after some moderate use and testing the areas between the rib supports is definitely caving in. If I had to due it over (and might still need to) I would use 3/4" ply on the top or a lot more rib supports.
Also be prepared to attach some surgical tubing, springs, or weights underneath the bridge to get the balance just right.
