Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 19-01-2012, 22:35
Programmer3941 Programmer3941 is offline
No Resistance. Absolute Power.
FRC #3941 (Absolute Zero Electricity)
Team Role: Student
Programmer3941 is an unknown quantity at this point
Re: Program deployed, no response from robot
Originally Posted by RahatAhmed View Post
We finally got it working. Our electrical team messed with the pins coming from the jaguars, and said they put them on channels 3 and 4 or something. Basically the pins suggested from the quick build were not the right ones. We're not sure why, or how we would go about adding new motors. I guess we'll figure it out.
RahatAhmed, my rookie team has been having a nearly identical problem with our Jaguar when we try to run a program we made to operate a single test motor. We have had absolutely no output response from the motor, and the yellow light on the Jaguar constantly flashes. We have not received any error messages, though, concerning the content of our code or otherwise. Could you explain in more detail what your electrical team did with the pins and channels to get the Jaguars and everything working?
Thanks in advance.
Unread 19-01-2012, 23:15
RahatAhmed RahatAhmed is offline
FRC #4300 (The Lion Kings)
RahatAhmed is an unknown quantity at this point
Thanks in advance.
I'm not on the electrical team, but they said something about moving the pins on the digital sidecar from the jaguar down two channels. So the jaguar on channel 1 is on 3, and the jaguar on channel 2 is on 4. I really don't know what this means, but that's all I know.
Unread 20-01-2012, 00:23
It might mean that your 37-pin ribbon cable is assembled wrong. If you plug it into itself, there should be no twist. See here for details.
Unread 20-01-2012, 17:02
Team Role: Student
I know for sure that our ribbon cable is fine (we've done the plugging into itself test). My team doesn't meet again for a few days, so I won't be able to look at everything we have set up electrically. Until then, are there any other common wiring issues that I should be aware of (we are very green in the art of electricity).
We have not tried moving the Jaguar pins into different channels yet (we will look at it when we have our next meet).
