Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 19-01-2012, 23:14
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
sharing a visualization of the ant build.xml dependency structure
Our team was trying to write a custom target in the NetBeans build.xml. Since there were so many targets in the sunspot build.xml it calls, it was making my heads spin thinking about the interactions. So I turned it into a visual dependency graph.
Sharing in case anyone else is reading the xml:
Ant terminology for anyone reading this who is confused:
  • build.xml - the name of the file containing instructions on how to build/package/deploy the java code
  • target - kind of like a method except in XML and it gets called differently
  • sunspot build.xml - comes with the plugins - has many targets and calls/includes other xml files with even more targets
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 19-01-2012, 23:23
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: sharing a visualization of the ant build.xml dependency structure
Whoa - that huge column gets impossible to follow!
What is your goal in doing this? In the preseason I tried to edit the build.xml so that we could have a process for deploying code that had already been built without recompiling it. I ended up leaving the file as is because I wasn't getting anywhere and I was causing strange errors.
Is your goal somewhat similar?
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 20-01-2012, 16:36
Java Mentor
The team is working on a simulator to run code without having a robot. (virsysj which is a java port). The idea is to right click the robot and either deploy to the robot or the simulator. Hence reading the Ant stuff. We didn't really need the visualization. I wanted to see it anyway.
Unread 20-01-2012, 16:38
Java Mentor
One key is we DID NOT touch their build.xml. We only touvhed the build.xml for our robot project. Which imports the monstor file in the visualization. I heavily used zooming to read the file though.
