Go to Post We are in the business of teaching our students. One of those things should be respect for the rules... - Tuba4 [more]
Unread 19-01-2012, 23:32
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Getting data out of a camera array + more
This is probably really simple but I can't figure out what block I need.
I want to get the data out of the vision processing block's array and I can't figure out how. The wire is pink if that helps. (see upload)
also... I tried to find the NI pdf that tells you exactly how to FTP the image processing files onto the cRio, but I can't. The only thing I can find is this: https://decibel.ni.com/content/message/30853#30853 Are there any step-by-step guides? I know some networking but I don't know everything about the file structure of the cRio or how to tell the program where the files are.
Thanks!
Unread 20-01-2012, 00:08
FRC #3476
Re: Getting data out of a camera array + more
Aww, can anyone help?
Unread 20-01-2012, 03:26
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
The are sine examples for the vision stuff. Typically all vision acquisition and recognition occurs in the vision vi and not in the periodic tasks vi. The Tracking data would then be sent via a global Vatican or functional global. If you need help with the globals then come and ask CD.
Mike B
Unread 20-01-2012, 07:24
It actually looks like this is in the teleop. That is not a good place to introduce vision. Vision acquisition and processing was broken out and placed in parallel so that teleop would not have to wait for the camera and image processing to complete.
As for what the pink wire is -- it is an image refnum. To get information from it, you have to use the vision functions from the vision palette.
Greg McKaskle
Unread 20-01-2012, 11:29
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
The pink wire is an array of clusters and needs to be unbundled. Attached is code that will do that. The input 'Index In' is what target information do you want. The vision processing routine returns up to four targets in the array.
Hope that helps.
Thanks!
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 20-01-2012, 18:04
Ahh. I didn't get that it was targeting data. The unbundle code shown is the way to go.
Good luck.
Greg McKaskle
Unread 22-01-2012, 13:12
FRC #3476
Thanks guys!
