Go to Post The key is to get the WHOLE TEAM to understand that you are designing and building a robot, which is a complete system - not just a collection of mechanical assemblies stuck together. - SteveGarward [more]
Unread 19-01-2012, 23:34
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
New CAD of our claw arm configuration
Here it is. And this only throws the ball. We have a way of putting it in the claw that we won't disclose just yet
Name:	arm and claw.jpg
ID:	11466  Click image for larger version
Name:	arm and claw 2.jpg
ID:	11467  Click image for larger version
Name:	arm and claw 3.jpg
ID:	11468  Click image for larger version
Name:	arm and claw 4.jpg
ID:	11469  Click image for larger version
Name:	arm and claw 5.jpg
Unread 19-01-2012, 23:35
FRC #4084
Re: New CAD of our claw arm configuration
Here's the rest
Name:	arm and claw 6.jpg
Unread 20-01-2012, 00:08
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
I fear that this design won't enable your team to shoot. Remember, there will be no dunking in Rebound Rumble. This is as a result of the Fender and the 14" maximum appendage. Keep that in careful consideration when proceeding further.
Good luck, though, and the CAD looks great!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 20-01-2012, 00:10
FRC #4084
We have a special thing that puts the ball in the claw and its a centripetal shooter. ran by a 4:1 CIM motor gear down from a direct sprocket 15 tooth the that huge sprocket on there that's 60 tooth that way we save as must energy by decreasing the amount of mechanical efficiency lose.
Unread 20-01-2012, 00:58
poohbear poohbear is offline
FRC #3815
poohbear is on a distinguished road
intriguing!
Unread 20-01-2012, 01:05
FRC #4084
Talking Re: New CAD of our claw arm configuration
Originally Posted by poohbear View Post
intriguing!
Thanks people! and also to spill another part of the design, we have algorithms set for the exact shots we want that makes the robot 99% computer and the claw doesn't actually rely on the servo power as a force to hold it in. It's held in by our calculations of the mu of friction of urethane to urethane between a urethane mold over the claw fingertip and the ball. So the servo gets a 1.1x boost and doesn't have to hold the ball, just apply perpendicular force.
Unread 20-01-2012, 01:13
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Question Re: New CAD of our claw arm configuration
Don't know if I understand...
Is the whole arm spinning rapidly releasing the ball?
Safety violations?
cole?
Unread 20-01-2012, 01:17
MikeBrock MikeBrock is offline
MikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond repute
This is really interesting. My team posted a catapult concept many days ago. Do you happen to have seen it?
I think specialized robots like ours will be very critical in the eliminations rounds when teams want balls thrown full field. Maybe make it a three-roller-claw instead of the three prongs?
Unread 20-01-2012, 01:23
FRC #4084
Could you elaborate on the rollers? Right now, we need as little weight on the arm as possible and based on estimates, our max is 10-12 pounds for both the ball side (with ball) and counterweight. And I believe we're hovering just around 5.5 pounds.
If you want, you can PM me and I can give you the low down on why and how we chose this design. It's awfully late for Texas but I'll look for the thread.
Unread 20-01-2012, 01:26
FRC #4084
Safety violations?
It doesnt violate safety rules it's fully enclosed except for the two side releasing and the arm is only 2 feet long. While it does spin rapidly, it's very safe unless for some reason you want to stick 1 foot of your arm into our robot. The electronics are mount around the cage shelf like and there's going to be 3 E-stop switches. Lol
Edit: arm is 2 feet from center of ball to center of counterweight
It also does continuously spin but for only 1.57 secs before optimum velocity then 1 sec of relate time speed analysis then release after <.05 sec
