Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 19-01-2012, 23:44
Re: 4-slot cRIO and default modules
That all sounds about right, other than that you could never put the modules wherever you wanted as far as I know. I believe it used to be Analog in 1 and 2 (may have been 1 and 3), Digital in 4 and 6 and solenoid in 7 and 8.
And yes, backward code comparability has not been maintained. All code that specifically referenced slot numbers (other than analog slot 1 which is 1 either way) must be updated to work in order to work with the new libraries and image.
EDIT: Just saw your edit. You must put Analog, Digital, Solenoid in that order in slots 1-3 on either cRIO (solenoid may be omitted). On the 4 slot, the 4th slot can be any module. On the 8 slot the pattern repeats with slots 5-7 with 4 and 8 left empty (any of the "extra" modules may be omitted, but the modules may not be shuffled around).
There's a description of the new paradigm in the C++ Getting Started Guide: http://firstforge.wpi.edu/sf/go/doc1197?nav=1
Unread 19-01-2012, 23:46
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Originally Posted by Joe Ross View Post
You've never been able to put the modules anywhere you wanted. Analog were slots 1 &2 (rules dictated you had to use slot 1), Digital were slots 4 & 6 (rules dictated you had to use slot 4), Solenoid were 7 & 8.
I meant "in theory". I am trying to understand the new paradigm, not that I really want to stick 3 analog modules in the cRIO.
Unread 19-01-2012, 23:52
mikets's Avatar
Software Engineer
Originally Posted by RufflesRidge View Post
EDIT: Just saw your edit. You must put Analog, Digital, Solenoid in slots 1-3 on either cRIO. On the 4 slot, the 4th slot can be any module. On the 8 slot the pattern repeats with slots 507 with 4 and 8 left empty.
So again, just to make sure I understand it correctly. In theory, if I put three analog modules in the 8-slot cRIO, the first one in slot 1, the second one in slot 4 and the third one in slot 5 (I suppose this is still legal ). I can address them by:
Gyro(1, 1);    //Gyro in slot 1, channel 1
Gyro(2, 1);    //Gyro in slot 4, channel 1
Gyro(3, 1);    //Gyro in slot 5, channel 1
Does it sound right? If so, they should have called it "instance" instead of "moduleNumber".
Unread 20-01-2012, 00:37
Not right. No modules are supported in Slots 4 or 8 of an 8-slot FRC-cRIO.
Unread 20-01-2012, 00:41
mikets's Avatar
Software Engineer
You said no modules are supported in slot 4 or 8. Is it because it's not allowed by the rules or is it because the code won't accept anything in slot 4 or 8?
Unread 20-01-2012, 09:54
The code doesn't support it because the hardware (FPGA) doesn't support it.
Unread 20-01-2012, 13:24
mikets's Avatar
Software Engineer
Sorry about beating the dead horse but I am just curious about why the cRIO has the extra slot and the FPGA does not support it. It seems to me the extra slot is very useful especially in the 4-slot cRIO. For example, it is quite easy to run out of digital I/O channels with encoders taking 2 channels each, teams may want to stick another digital module in slot 4, for example.
Also RufflesRidge mentioned slot 4 of the 4-slot cRIO can take any modules.
Unread 20-01-2012, 13:40
You can stick whichever module you need in slot-4 of the cRIO FRC II.
The older cRIO FRC I, was just given the 3+0+3+0 pattern as a design choice. We are unlikely to mix the two up.
The FPGA is really full with all it's been given to do.
Excess capacity got sucked up to benefit us in other much more potentially useful ways.
All resources are limited in one way or another.
Engineering is designing and choosing between the optimal tradeoffs for our application.
Unread 20-01-2012, 17:00
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Smile Re: 4-slot cRIO and default modules
You must have grown up only on a Windows machine. Windows only supports (without weird hacks) absolute paths for shortcuts. If you had grown up with Linux you would have used the symbolic links method (relative paths - module numbers not slot numbers). Then the code wouldn't have to be changed .
Speaking of dead horses...this is just wrong. LOL
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 20-01-2012, 17:29
mikets's Avatar
Software Engineer
Actually, I grew up with punch cards and unix
Unread 20-01-2012, 18:10
Luxury...
Unread 20-01-2012, 21:42
I hope I don't add to the confusion, but it is worth mentioning that the cRIO FPGA is reprogrammable. In its day job, it can have 8 32-bit digital modules if you like, and it is also possible to compile in a slot manager that will map the slots dynamically and make it truly plug-n-play. But, all of this is dependent on the FPGA, and the FRC FPGA uses fixed slots and has a ton of flexibility in what the pins can do.
Greg McKaskle
Unread 21-01-2012, 21:17
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Originally Posted by Mark McLeod View Post
Luxury...
I've never had the fun of programming a machine with switches and push buttons, but some co-workers have shared many a story about entering bootloaders this way (and even more arcane methods).
- Bryce
Unread 21-01-2012, 22:20
mikets's Avatar
Software Engineer
I've never had the fun of programming a machine with switches and push buttons.
I've done that too with the PDP-11.
Unread 30-01-2012, 01:28
BitWizard BitWizard is offline
FRC #0279
BitWizard is an unknown quantity at this point
Greg, we were planning to go with two analogs in slots 1 and 4, and two digitals in slots 2 and 3 on a 4-slot cRIO. We're ordering a 4-slot specifically for that purpose. Are you saying we can't do this. We have no pneumatics this year.
Chris
