Go to Post Fancy that, better robots winning matches... - DampRobot [more]
Unread 20-01-2012, 00:16
Re: Programming Logitech Extreme 3D Pro
There is a function in LabVIEW called "In Range and Coerce". You can use the value of the throttle knob as the "maximum" input of the function, and use its negation as the "minimum" input if you want. The coerced output will follow the function's input, but will be limited to always be no lower than the minimum and no higher than the maximum.
Unread 20-01-2012, 03:18
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
This will work, but well make a hard limit. The other solution post a few times makes a soft limit, applying the limit linearly across the whole a axis. There are reasons to use either. Your drivers may have an opinion on which way you pick.
Mike B
Unread 20-01-2012, 11:41
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Thanks for the help so far, I was thinking would we be able to wire a potentiometer to a bread board and use that instead of trying to use a joystick for this function? If possible how would I program it to interact with the motor?
Unread 25-01-2012, 23:31
SuperS_5's Avatar
FRC #1219
I am not sure if you mean on the robot or driver station. If you meant the driver station, this wouldn't be very easy, and a joystick would make much more sense.
If on the robot, then it is a bit easier, but I still don't recommend it. It would add complexity to the robot wiring/programming, (depending upon how it would be used) weight, and not be adjustable during a match. Again, I suggest sticking to your original idea of a joystick axis. If you want something more difficult to modify while in use, you could always use a custom dashboard with a throttle slider on it.
Mike B
Unread 26-01-2012, 00:49
The Cypress board will work for connecting a potentiometer to the Driver Station. In the simple "compatible" mode, you can read up to four analog inputs and use the returned value to govern your motor speed.
You don't even have to use a physical potentiometer if you don't want to. The Driver Station has an I/O tab that lets you set the value of a virtual analog input, which the robot can read as if it were a real analog value.
Unread 26-01-2012, 01:44
SuperS_5's Avatar
FRC #1219
Thanks for mentioning this, I had completely forgotten about those.
Mike B
