#15
Re: Varying Regulator Pressure Using Mechanical Device
J.
[R72] If pneumatic components are used on the Robot, the following items are required as part of the pneumatic system and must be connected in accordance with this section. D. An easily visible and accessible pressure vent plug valve to manually relieve the stored pressure (see Rule [R77]). [R77] The pressure vent plug valve must be connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure. The valve must be placed on the Robot so that it is visible and easily accessible. One only, sorry. |
