Go to Post I got dragged into FIRST against my will, and it was the best thing that's ever happened to me. - Liz C [more]
Unread 20-01-2012, 07:44
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
cross the Barrier
What we should do if we are a rocky member and we did not access to use Mecanum wheels 8" to across the barrier and we need to know other ideas of across the barrier?
TEAM 1946-Tamra
Unread 20-01-2012, 08:29
pfreivald's Avatar
AKA: Patrick Freivald
Re: cross the Barrier
You can try skid plates (an angle that serves as a wedge before your front wheels are contacted) or perhaps another set of idler wheels set higher.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 20-01-2012, 08:50
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Pneumatic tires are good shock absorbers.
Unread 20-01-2012, 08:57
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
you could use some form of skii's and use more wheels to reduce the gap like were gonna use 4 on each side instead of 3.
Unread 20-01-2012, 09:12
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
How about a whole row of small wheels all along the frame? We're not going to do that, but with enough momentum and 4-wheels driven, it should just sail over the rail. The little wheels in the middle should be 3.5" from the floor for maximum effect. Maybe a two-wheel lead in at the front with two sizes would be more effective than a skid. We might even actually try that. Roller blade wheels as the second wheel maybe?
Just remember, free advice is likely to be worth just what you paid for it.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
