Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 20-01-2012, 10:43
Re: Calculating distance with an Axis Camera 206
Originally Posted by Chris_Elston View Post
The bigger the area, the closer you are. The smaller the area, the further away you are.
A smaller area could also mean you are just farther away from the line perpendicular to the target, even if you are the same distance from the target itself.
Citrus, what algorithm are you using to compute distance?
