Re: LabVIEW: Unable Install Code (Access Denied)
I am having a similar problem (I think)
We have the latest image on our robot, but when I try to deploy the code from Labview, I get this error message: "Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer." The thing is, when I look at MAX, Both my computer, and the cRIO are using Real-Time 11.0 (11.0.0). I tried reinstalling Real-Time on the cRIO, but it didn't change anything. Any help/ideas/anything would be welcome! |
There are easy ways to check your FRC versions on both the cRIO and PC LabVIEW installation.
Fire up the Driver Station application, connect to the cRIO and the Diagnostics tab should display the version numbers of the
Fire up LabVIEW and verify the version: Help -> About FIRST Robotics Competition Software...It should say "Software Update 4.0.0" |
Hey,
We are having the same problem between Labview and Compact C-RIO. When I open Labview it says click for mandatory update wheras I've done it too many times. And also the version of labview is still 3.1 but Mr Mcleod says it must be 4.0 What am I missing ?? Is there any idea that can help ? |
If you're talking about the "FIRST Robotics Competition Software 2012" update number, you might not have run the mandatory FRC LabVIEW update. On page 3 of the Getting Started with the 2012 FRC Control System document, it says: After you’ve installed your programming language base software, all teams must install the language specific updates. |
