Go to Post In conclusion, we can say, with reasonable certainty, that we know nothing. - Max Lobovsky [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 20-01-2012, 11:08
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Jaguars Do Not Connect to BDC-COMM
Originally Posted by Bryscus View Post
- When using a Jaguar in a closed loop mode (speed, position, current), if the Jaguar shuts down for whatever reason (overheating, overloading, tripped circuit breaker) it will reboot in open loop voltage control mode. It will then ignore any closed loop command signals you send it because it is looking for voltage commands.
I would like to elaborate on this. You are correct that whenever the Jag reboots/resets (usually after a brown-out or a power cycle) all parameters and running modes are reset to default (voltage mode) except for the ID. However, overheating and over current won't necessarily reset the Jaguar. The Jaguar will go into a fault mode and shut off the outputs for a few seconds (to attempt to alleviate the problem) and then pick up right where it left off.
That being said, it is definitely possible for an over current condition to happen so fast that the Jaguar can't fault in time. The current spike can dip the supply voltage so much that the Jaguar browns out and therefore resets.
-David
