Go to Post There's something about building a robot that just makes people enthusiastic about life. - BBnum3 [more]
Unread 20-01-2012, 02:36
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Van Door Motor output shaft
Does anyone know of a good adapter for the Taigene Van Door motor sold at AndyMark?
http://www.andymark.com/Van-Door-mot...-p/fc12-72.htm
I found this DD Key shaft adapter, but the dimensions don't seem like a good fit:
http://www.andymark.com/product-p/am-0165.htm
Also, this hex adapter may work, but does anyone know where to get hex shaft couplings?
http://www.andymark.com/product-p/am-0168.htm
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 20-01-2012, 07:24
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Van Door Motor output shaft
We have made our own in the past. If you have machining and welding capability, bore out some steel rod to slide fit over the shaft. Then mill a flat(s) through the bore to match the depth of the flat(s) on the shaft. Then weld flat stock across the flat(s) to engage the shaft. Alternately, you can visit your local dealer parts counterm, see what the van door motor drives, and you may be able to adapt that for your needs. Your choice.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 20-01-2012, 12:00
seg9585's Avatar
AKA: Eric
Rookie team has no access to a mill or lathe, or any welding equipment. I've been searching around locally, but have been unable to find something the right size (even on McMasterCarr) that can directly couple this shaft to another driveshaft.
Any other teams? How did you mount this motor?
My FIRST legacy:
Unread 20-01-2012, 13:12
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Is it legally for FRC 2012
TEAM 1946-Tamra
Unread 20-01-2012, 13:22
The couplers? Sure. COTS from a Vendor.
The Van Door motor? Well... That's a tricky question. You're allowed two by the ARA allowance or raiding old KOPs. The question is, is buying an equivalent motor from AndyMark going to be legal? I don't think anybody's asked Q&A that one yet (and I don't think you'd get a usable answer from them, given their track record on tricky questions this year).
Unread 20-01-2012, 13:41
seg9585's Avatar
AKA: Eric
Prior year's KOP... once again, we are a rookie team. the Van Doors are provided by FIRST Choice and are equivalent to motors in the former years' KoP. Why would it not be legal to get an equivalent motor?? If this is indeed illegal, it would be a HUGE disadvantage for a rookie team.
My FIRST legacy:
Unread 20-01-2012, 13:58
Right. That's the commonsense approach, which I would normally consider a good one. But... we're dealing with rules that give a source here.
I. up to 2 window lift, seat, windshield wiper or door motors obtained through either the FIRST-Automotive Recyclers Association partnership or from a prior years’ KOP.
Note: It will be up to the teams to show that the motors used on the Robot are legal by providing paperwork showing the motor’s original use, i.e. if it’s called a “seat motor” on the ARA receipt, it is a seat motor.
(emphasis mine)
The question is, is an equivalent motor not obtained through either the ARA or through an old KOP legal? In the spirit of the rule, I would say so; otherwise, rookie and sophomore teams do not have the available power that everyone else does (without raiding the local ARA for parts, which may not be practical for some teams, say the Canadians or Israelis). By the letter of the rule, however, it is not legal.
[deleted question for Q&A]
EDIT: Actually, someone already asked Q&A. The FIRST Choice van door motor is legal. Common sense wins.
Unread 20-01-2012, 17:59
seg9585's Avatar
AKA: Eric
EricH, by my interpretation of the rule you post, it IS totally legal because this Van Door motor WAS in a prior year KOP. The fact that the physical motor itself was not a used motor in a physical distributed kit doesn't matter. The Kit of Parts is an idea, not an object.
Philosophy aside, I really wanted to get back to the question at hand, and that's how have teams have attached this motor to an actuated driveshaft in the past, or can give us tips on where to get such a compatible item??
My FIRST legacy:
Unread 20-01-2012, 18:29
Right. That's the interpretation the Q&A had as well. See the edit in my post above. (Or did you read that far down?)
The other interpretation, which is the one I had before seeing the Q&A, was the "rule says these sources, this is not repeat not repeat not one of those sources, therefore illegal". This interpretation is now null and void (and I'm glad someone asked the question before inspections, otherwise an inspector might have taken the interpretation I did).
Unread 21-01-2012, 09:00
Hodge1
What are you planning to drive with the van door motor? Have you tried contraction your local vo-tech, community college, or a local high school that might have the equipment to make the part for you. Are you connecting to a shaft or drum?
Sweat the details
Unread 21-01-2012, 09:08
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
In 2006 we drilled a hole the same diameter as the motor shaft in one of our rollers, and drilled through the shaft and roller, and pinned it with a small bolt. As I remember, the shaft was not hard to drill.
Unread 21-01-2012, 09:12
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Weld a sprocket on the output shaft.
Unread 21-01-2012, 10:57
Hodge1
They don't have the capability to weld, mill, or turn parts. PM me and I should be able to help you if you give me some detail on what you want to drive with the van door motor.
Sweat the details
Unread 08-02-2012, 09:19
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
AM sells a hub with a 10MM hole. The door motor shaft is 11MM or .435 in. according to AM. A 7/16 drill is .4375. This is slow speed so if it was me and I had only a drill press I would buy a hub with either a 10MM hole or smaller and drill it out with a 7/16 drill. Actually, that is exactly what we did last night.
Hope that helps.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 10-02-2012, 01:07
seg9585's Avatar
AKA: Eric
Thanks all. Decided for our application, drilling a hole through the DD bore portion of the shaft and using a bolt as a drive pin will do the trick. I'm sure there are more elegant ways to do it, but Week 6 is upon us :-)
My FIRST legacy:
