Go to Post [Don't] celebrate mediocrity and want the losers to have an equal chance? Please. Work your butt off for six weeks, keep doing it until you have taught yourself how to be excellent, and go and instead of waiting for a handout. - DonRotolo [more]
Unread 19-01-2012, 19:52
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Kinect x-axis
How is the x axis used from the Kinect? Not how is it programmed, but what motion is it?
I've looked at the picture that shows the axes, but I don't know what to make of the x-axis.
Unread 19-01-2012, 19:54
Re: Kinect x-axis
Note: The KinectStick class returns 0 on the x-axis unless you edit the Kinect Server
Assuming you are talking about joint coordinates, if you are looking at the Kinect device and it is looking at you, the Z-axis is towards or away from the Kinect, the Y-axis is height and the X-axis is left-right.
Unread 20-01-2012, 11:03
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: Kinect x-axis
The x-axis is the distance from the center of the with the right being +1 and the left being -1. the y value is the same with the with the top of the image +1 and the bottom -1. the z axis is a little bit more tricky, it is the value you are from the sensor, so i took the value of the spine and subtracted it from the hand (if your using it), the value differential from you spine with your arm straight forward is about 0.5
Unread 20-01-2012, 14:00
Re: Kinect x-axis
Your directions are correct, however the Kinect axis values are not normalized in the manner you suggest. They are values in meters, if you stand far away from the device and move left or right to the edges of what the Kinect can see you should be able to get values over/under 1/-1
Unread 20-01-2012, 15:23
Re: Kinect x-axis
true i didnt think about that
