Go to Post I don't fully buy into the 'we're all winners' concept. That is a broad statement that doesn't really say much. How did we become all winners? What did we do to become winners? Pay an expensive registration fee and participate in a robotic competition? - JaneYoung [more]
Unread 20-01-2012, 14:08
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: Wifi AP connection to bot
Originally Posted by sebflippers View Post
Our team is trying to get last years robot to work wirelessly. We have never gotten it to work yet. Our current setup: driver station connected through the bridge to the cRio (100% ethernet tethered). Works perfectly. On the diagnostic page of the DS the "Ethernet","Bridge" and "robot" lights turn green. When I disconnect it the DS tries to connect wirelessly. The "ds radio" and "bridge" blink at random intervals. Once, they both blinked at the same time, and stayed for about 3 seconds. Then the robot light turned green too, but it died so fast I wasn't able to test it. Is the bridge dead or what?
seb
OK. From what it sounds like, you're trying to create a WiFi link between the Classmate (or whatever laptop) and the DAP-1522 bridge. In order to do this, the bridge has to be in Access Point mode. I believe the instructions do NOT set it up with way, but I could be mistaken. I this scenario, the bridge is broadcasting an SSID (wireless connection name) so that DEVICES may connect to IT. You also probably need to set a static IP in this situation because the bridge wouldn't be set up for routing.
NORMALLY, for competition at least, you set up the bridge for BRIDGE mode. In this case the BRIDGE is the DEVICE and a main router is the access point. Thus, you would turn off WiFi on your laptop and connect it through a wired connection to the router. Then the bridge would connect to the ROUTER'S wireless network which would then allow your robot and DS to talk (because they're now connected on the same network).
I think you're trying to merge the two situations and the bridge is not connecting to the router because the router isn't even involved. Is this correct? I hope this helps. I may be misunderstanding you situation.
- Bryce
P.S. In the current setup you could possibly set up an Adhoc network with your DS laptop which would then allow the bridge to connect to it as well. You would have to set a static IP for this.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
