Go to Post ANY team is capable of producing a winning design. This does NOT require anything more than brainpower, and time. - Racer26 [more]
Unread 20-01-2012, 12:26
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Camera Image w/o CRIO?
This year, we are planing to make our own dashboard in java. If we hook the camera directly to the radio, how would we go about accessing the camera image from the computer running the driver station?
Since the Axis Camera has a URL for the MJPEG and JPEG images, could we some how stream the MJPEG directly? or would we have to constantly get JPEG and keep on updating the image on our dashboard?
This code seems like it would work but it seems like they are using a custom package. http://www.walking-productions.com/n...lash-and-java/
Unread 20-01-2012, 12:41
rockytheworm's Avatar
rockytheworm rockytheworm is offline
AKA: Chris Kirk
FRC #1517 (Lumberjacks)
rockytheworm is an unknown quantity at this point
Re: Camera Image w/o CRIO?
We used this block of code and it worked:
cam=AxisCamera.getInstance();
cam.writeResolution(AxisCamera.ResolutionT.k640x480);
cam.writeBrightness(0);
If your camera is formatted for use through your radio it should work fine.
Unread 20-01-2012, 14:29
That code goes in the CRIO, basically we want the image to go directly from the camera to the control computer. We really do not want to get the CRIO involved at all.
Unread 20-01-2012, 14:45
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
I'm pretty sure you could find the mjpeg stream via an HTTP connection
