Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 20-01-2012, 16:49
ColonelThrtyTwo's Avatar
ColonelThrtyTwo ColonelThrtyTwo is offline
FRC #3676
ColonelThrtyTwo is an unknown quantity at this point
Re: NI Vision Functions
Originally Posted by AjFoster View Post
We get the following errors:
taskExecutor: cannot find symbol
assertCleanStatus: cannot find symbol
You need to instantiate your own TaskExecutor and pass it to setTaskExecutor. assertCleanStatus is a protected method of the NIVision class, which checks if its argument is nonzero and if so throws an NIVisionException. Why it is protected, I don't know; you can't extend the classs because the only constructor is private. Just make your own, or copy+paste the source code from NIVision.java.
Is there any documentation for the imaq functions C-side? Specifically, I would like to use imaqDetectRectangles and need the fields of the RectangleMatch struct.
Unread 20-01-2012, 17:02
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Look in C:\Program Files\National Instruments\Vision\Documentation\NIVisionCVI.chm
-Joe
Unread 20-01-2012, 17:08
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
The way I did it was to make a new executer, and copy and past the assertCleanStatus function from the NIVision.java.
Unread 20-01-2012, 23:07
AjFoster AjFoster is offline
Hydra Robotics - 2425
AKA: AJ
FRC #2425 (Hydra Robotics)
AjFoster is an unknown quantity at this point
Thanks so much for the tips - everything runs error-free now.
Would it be possible to see an example of convexHull() being properly called (for an image which I've already used an HSL threshold on)?
Aj Foster
Team 2425 - HYDRA Robotics
Hillsborough High School
Tampa, Florida
Unread 21-01-2012, 20:28
FRC #1700
Sure, here is an example of how I call it:
convexHull(binaryImage.image,binaryImage.image,1);
That will find the convex hull of binaryImage and put it in binaryImage
Unread 12-02-2012, 18:16
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Does anyone know if there is full documentation of the NIVision C functions anywhere to make this process easier?
Unread 13-02-2012, 07:13
Program Filles/National Instruments/Vision/Documentation.
Specifically, you should look at the CVI document.
Greg Mckaskle
Unread 13-02-2012, 14:02
http://www.chiefdelphi.com/forums/sh...4&postcount=14
