Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 20-01-2012, 17:09
eternitykid eternitykid is offline
FRC #2879
eternitykid is an unknown quantity at this point
How to use extruded aluminum
How would someone cut, mount and use extruded aluminum channel? The part in question is fc12-14, made by AndyMark.
Unread 20-01-2012, 18:08
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: How to use extruded aluminum
Welcome to the forums. Extruded aluminum can be cut with any saw with a metal cutting blade. If you have one, a band saw works well. If you're a low budget team a hack saw works.
Extruded aluminum mounts using special brackets which connect to other pieces of extruded aluminum. See the link on the AndyMark page for more info.
